Question about Yamaha RX-V1500 Receiver
The display tern on an tern off in a very short time. All speakers and power cord conections are firmly. No sound. I disconet de power cord for about 30 secons and the problem continue.
Posted by rodzprpr39 on
David Dunn
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 30, 2011
Power cord is shorting out
The cable guy may have bumped the power connector and loosened it. Try pushing it in firmly. Sometimes the power connections get loose over time
Oct 03, 2012 | Toshiba Televison & Video
Getting an error display as "Push power protector" in my Sony Home theatre - DAV DZ777. what is the solution.
Turn off your unit at the power button. Check speaker outputs for a short circuit - also check other end of speaker cables for a short. If you can't find an obvious problem then disconnect all speakers and power up the unit. If all is OK then connect speakers one at a time (this should be done with the unit powered OFF) and power up after each conection. This should identify which output is causing the problem.
If that does not work then it's an internal fault that will require a service engineer to identify - but I hope that is not the case!
Jan 21, 2011 | Sony DAV-DX255 System
Where can I find a diagram and instructions to change #7 injector in my 2004 Ford F350
this is a fairly delicate operation and should be peformed by your dealer
or a diesel repair shop even an international teck could do this for you
it not impossible to do in your (back yard) providing you take your time
no special tools needed also after instalation disconet crank and cam
sensor to prevent engine to start causing dry fire and crank over 2-3 time
to re prime system then conect and start engine and let idle to let remaining
trap air out
the injector is self extracting when clamp is unbolted just be carfull not to
damaged any other when oil rail is removed (upper o-rings)not servicable
make sure injector clamp is firmly and properly seated
good luck take your time
Jan 12, 2011 | 2004 Ford F350
I have a intel media series dp35dp motherboard. I have a power led cord, reset sw cord, power led cord, m/b sw cord and a speaker cord for the speaker on the chasis. When I plug them up I don't see a spot...
in newer generation motherboard the buzzer is built in in there is no need to connect an chasis speaker if built in buzzer is not there uwill find a four pin conecter near the power pannel you nedd to conect the pwer switch and reset switch in proper conector or the system wont powerup properly
Sep 25, 2010 | Intel Computers & Internet
I have no sound at all from my Soundsticks. They have never been dropped, I've checked my mixer, and tried both volume buttons. Just no response. There is no visible damage anywhere and they have always...
Is the power light lit up? If not, double check the AC cord is firmly in the brick adapter, and the plug is firmly in the subwoofer with the arrow facing up. The ac cord may look like it is in tight, but not be. Unplug it and replug it to make sure. Make sure the ac cord is plugged into a good power jack. If you have the brick plugged into a surge protector or power controller,make sure they are on (not off, or 'reset') If you still don't have a light, take the brick to a electronics store (radio shack, etc) and have them check the output voltage. A replacement power brick is not that expensive, especially a third party one.
if you do have the light on, try plugging them into an MP3 player, cd player, or pretty much anything with a headphone jack. Hit the vol up (+) a few times.
If they work there, it's a computer sound issue (wrong plug, muted, headphones plugged in, etc) . If it doesn't work using an mp3 player (or equivalent), you may have a bad audio cable, or the speakers may have simply gone bad.
Sep 08, 2010 | Harman Kardon SoundSticks II Computer...
My yamaha reciever has a power problem in that when i switch it on, it only goes on for a few seconds and thereafter goes off.
As long as you're sure the power cord is firmly plugged in, it sounds like the protection circuitry of the unit has likely been activated. This happens when there is a short circuit in one of the connections. Check your speaker wiring connections and make sure all of them are firmly and carefully grounded (i.e. the copper of the wire touches nothing but the proper terminal, and that the wires do not touch each other). Check the connections on the speakers as well. If protection circuitry is the result of a shock or power surge (lightning, strong static, etc.), you can reset it. Turn it to standby mode, unplug it, wait for 30 seconds, then plug it back in.
Jan 20, 2010 | Yamaha HTR-5630 Receiver
Yamaha HTR-5760 goes to standby 2 seconds after power on
Maybe your device got the audio amplifier IC damaged
Jul 02, 2009 | Yamaha HTR-5760 Receiver
RADIO WONT WORK
CHECK YOUR POWER CORD GOING INTO THE RADIO THE CONECTION TENDS TO GET LOOSE AFTER TIME
Mar 30, 2009 | Bose Wave Radio
Yamaha RX-V1500 Receiver Logo
41 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
