Scientific Toys North Pole Express Xmas Train set Logo
Anonymous Posted on Jan 30, 2011
I have a rio grande toy locomotive but the lightbulb stoped. How do you change the lightbulb.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 30, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5691
Points
10
A train hobby shop can fix that.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
734
Points
Hobby lobby
can fix
that
I have a scientific toys union pacific g scale locomotive No.3691. Will cutting the wires for the smoke maker thing damage the rest of the train?
I don't think it will, but you only need to cut one wire. That reduces the risk of the two wires shorting and damaging something. Tape off the wire so it won't accidentally contact anything. You might first want to check the manual to see if there is a way to disable the smoke generator without cutting anything - maybe there's a hidden switch that does the job.
Nov 26, 2022 • Toys
Brio 512 Mighty Red Engine Locomotive. I got the triangle screws out of the underside. Bottom seems stuck. What is the small red button?
'Triangle Screws' are security screws so that you can't remove them. Your question is a bit to specialised for Fixya, so contact the maker direct. They may just say, "send it back and we will replace it, or repair it".
33592 Mighty Red Action Locomotive ' BRIO World Toy Trains
www.brio.us > railway > trains-wagon-and-vehicles > m...
Classic BRIO design: This durable, retro designed toy allows your child's imagination to flow and helps improve their fine motor skills and spatial awareness.
2answers
My scientific train Rio grande wont t start Its a toy one with plastic track, batteries are good just wont turn on
I would suspect a bad switch or a bad motor.
These parts are not available anywhere that I have ever heard of.. You might go to the store you purchased it from and ask them.
God bless your efforts.
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Locomotive moves then stops
If your locomotive continuously starts then stops, when prodded with hand/finger repeats process. Then most likely, first check your electric connection for a loose connection. If everything looks ok, check wheels on locomotive for dirty wheels, then check track for dirty track.
Lionel train wheels stuck on locomotive
What locomotive? Which wheels? Are they stuck if you try to turn them by hand or don't they turn when you supply power to the locomotive?
Dec 28, 2012 • Toys
Strasburg steam locomotive receives power, but does not move.
Try cleaning the track AND wheels with an INK ERASER. Put the engine on the track and help it along. It could just be tight from sitting in the box. I live about 8 miles from the Strasburg railroad and have 2 relatives working there. We have ALL experienced the same thing on4 different sets. It isn't just the Strasburg sets that do this, it's most of the new toys. Your Strasburg cars might not connect to other train sets. Their car couplings are different, just like on their real trains.
Dec 13, 2012 • Toys
I recently purchased a Dash 9-44 CW Diesel locomotive. It has on the label of the box "Command Equipped" - "Towercom TM" - "Crewtalk TM" - "Railsounds TM". My...
I'm not familiar with the Dash 9-44 CW but it may be that the sound and smoke switches are turned off. You will probably find these under a removable cover on top of the locomotive or under it, usually near the cab. Check your instructions or go to Lionel.com and click on support. Instructions and manuals can be found here.
Apr 29, 2017 • Lionel Toys
1helpful
I have a rio grande train set and I can not figure out to put the tracks together?
HOLD TWO PIECES OF TRACK TOGETHER SNAP ONE SIDE TOGETHER THEN SNAP OTHER SIDE.
Top Scientific Toys Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Scientific Toys Toy Expert? Answer questions, earn points and help others
