Question about Philips CDR760 CD Player
Hi
maybe is to late but here is the complete guide of opc fail on this machines. First of all you may noticed that the very old TDK or Philips discs still record as they should. The new cd digital audio media have a "toc" info above 32x speed, and for the old 760 model the firmware cant see or read any kind of media above 24x. I am pretty sure that on this days there are no media makers with this low speed toc info. Regardless of Brand keep in mind that old TDK and Philips or some older Sony's are made by CMC magnetics. here is the complete info of one old TDK that Works flawlessly on this kind or recorders:
Erasable: No
Free Sectors: 359,847
Free Space: 736,966,656 bytes
Free Time: 79:59:72 (MM:SS:FF)
Next Writable Address: 0
MID: 97m26s66f (CMC Magnetics Corp.)
Supported Write Speeds: 10x, 16x, 24x
ATIP Information:
Disc ID: 97m26s66f
Manufacturer: CMC Magnetics Corp.
Start Time of Lead In: 97m26s66f
Last Possible Start Time of Lead Out: 79m59s74f
Performance (Write Speed):
Descriptor 1...
-> B0: 0x00, B1: 0x00, B2: 0x00, B3: 0x00
-> EL: 359998 (0x00057E3E)
-> RS: 4,234 KB/s (24x) - WS: 1,764 KB/s (10x)
Descriptor 2...
-> RS: 4,234 KB/s (24x) - WS: 2,822 KB/s (16x)
Descriptor 3...
-> RS: 4,234 KB/s (24x) - WS: 4,234 KB/s (24x)
the only solution that I know that Works is to buy a mod chip in order to get the recorder be alive again. But you must find a person with the skills to get the chip soldered.
Posted on Jan 21, 2014
There are a lot of forums which discuss OPC failure and it strikes every hardware maker and brand of media.
The bottom line is that certain media and certain writers just don't get along.
The manual:
http://www.p4c.philips.com/files/c/cdr760_17/cdr760_17_dfu_aen.pdf
Discussion online:
http://homerecording.com/bbs/general-discussions/recording-techniques/phillips-cdr870-187247/
http://answers.google.com/answers/threadview/id/318687.html
"I don't buy expensive blanks. I buy modest quality blanks and watch
for sales so that I can them for about a dime a piece after the rebate
check comes in. If I have an OPC Fail message, I try another blank. If
I find that they consistently fail (about half a buck wasted) I move
the stack over to the computer (which seems to work fine with these)
and buy another stack of blanks of a different brand next time I see a
good price..."
an interesting workaround:
http://www.sweetwater.com/forums/showthread.php?10128-Tascam-CD-RW5000
"CDRW 5000 work around for OPC FAIL
Here's a work around for OPC FAIL on cdrw 5000 -
method 1: turn unit on at least 30 minutes or more before use (this seems to work best for me)
method 2: run OPC on an old cd that always works - after OPC passes, remove old cd and insert new CD (you only get 99 OPC runs per disc)
-or use a combination of the two methods
I've always used TDK and I recently bought a new batch and they stopped working. The old ones still work everytime. I don't know enough about the system to guess what the difference is.
side note: CDRW 2000 will finalise discs from the cdrw 5000 but not the other way around.
Hope that helps "
Posted on Jan 30, 2011
Dec 16, 2010 | Philips CDR870 CD Recorder
Apr 17, 2010 | Philips CDR778 2-Disc CD Recorder
Mar 19, 2010 | Philips CDR870 CD Recorder
Feb 06, 2010 | Marantz DR-4050 2-Disc CD Recorder
Jan 18, 2010 | Philips CDR870 CD Recorder
Oct 11, 2009 | Philips CDR765 2-Disc CD Recorder
Jun 23, 2008 | Philips CDR760 CD Player
Dec 04, 2007 | Marantz DR-6000 CD Player
Oct 02, 2007 | Philips CDR570 CD Recorder
Dec 07, 2005 | TDK DA-3826 2-Disc CD Recorder
Apr 08, 2017 | Philips CDR760 CD Player
May 23, 2012 | Philips CDR760 CD Player
Aug 17, 2011 | Philips CDR760 CD Player
1,985 people viewed this question
