Some keyboards have a feature called "Number Lock" It is mostly found on laptops. But turn it off to regain your default keyboard. On most keyboards it is located near the screen shot, print screen buttons. Push your shift key and the NumLk/ScrnLk button, and your keyboard should return to default.
Hope this helps...... :)
Posted on Jun 26, 2012
Thanks. It worked. I guess I need to get out the manual.
thank
Fn+inser on ****
safe
st533 d6nt w6r2
n6*e st533 d5dn't w6r2
456*1230
I was trying to find the Numlock button at my net book keyboard, but NO THERE. And than i found BLUE Icon under F11 showing Lock with number 1 inside it. When you press FN and this icon, your problem will be solved as was solved mine in a second! :-) Hope it helps to someone...
Posted on Jan 04, 2013
Hold shift and press scroll lock. 0y 2eyb6ard 5s ********. d6 5t aga5n- My keyboard is not ********. OOOOOhhh s6 a0az5ng weeee!
Posted on Mar 03, 2012
Fn + Delete.
Posted on Feb 05, 2023
can you post in English.
seems your keyboard is bad, replace it.
or get PC repaired in a real shop
no PC model or maker told.
K key is not effected by num lock key.
ever.
is this a wire less keyboard,
if yes the batteries in it are dead.
(super weak)
