Question about Samson C01U Consumer Microphone
Hi i have a problem with samson c01, it doesnt work because i use a pc and a usb cable. no power , what can i do?
Posted by csm_76 on
Andrew Conroy
    Sergeant:
  • 298 Answers
Some users have reported problems with this microphone not working properly with Windows Vista operating system but it is fine with XP and Windows 7. Some MAC & Linux users have also encountered installation problems.
All condenser microphones require a power source to make them work. In the case of USB mics they take their operating power from the computers USB port. If you have a lot of other USB devices connected then there may not be enough power available to run them all at the same time. Disconnect any devices that you do not need.
First step would be to make sure that you connect to a main USB port (not a separate hub). If you are using a desktop or tower computer use the USB ports on the rear of the computer, which are mounted directly on the motherboard. Front panel USB ports are normally on a hub and may therefore prove unreliable with some devices..
Next try to diagnose the problem by process of systematic elimination
  1. Test your sound-card - does it work okay with other sound sources such as a microphone plugged into the normal microphone input (red socket) on the sound-card or on your front panel.
  2. Do you have another USB sound source that you can plug in to make sure that your computer will accept sound from that route?
  3. Now check the microphone for faults. Is the LED on the microphone coming on to indicate it is getting power?
  4. If no the microphone itself, or the cable, may be faulty. Try plugging it in to a different computer, games console, stereo or audio device with a USB input to see if it will work there (note not all audio devices will have sufficient power on the USB socket so this test may not be conclusive)
  5. Is the computer operating system actually recognising the presence of the microphone in the first place?
  6. Does a little balloon pop up to say a device has been plugged in - and does it correctly identify what that device is by telling you it's name?
  7. If the system recognises the device but doesn't correctly identify then you may need to install a driver for the microphone.
  8. From the windows start menu go to CONTROL PANEL.
  9. Click on SYSTEM, then HARDWARE, followed by DEVICE MANAGER
  10. Scroll down to SOUND VIDEO & GAME CONTROLLERS. Does the microphone appear here? If yes does it have a little yellow asterisk next to it? If so it is a driver issue.
  11. Sometimes a USB driver issue can be resolved by uninstalling the USB controllers and reinstalling them. Scroll down the list of devices in DEVICE MANAGER until you get to UNIVERSAL SERIAL BUS CONTROLLERS. Systematically uninstall every device listed here. To do this RIGHT CLICK on each device and then click UNINSTALL. Then on the TOOL BAR click CHECK FOR SYSTEM CHANGES. this will reinstall all USB devices and controllers.
  12. If that does not solve the USB problem go to your computer manufacturers website and download the latest USB drivers for your machine.
  13. Assuming you have overcome the USB issue (or if this was not the problem anyway) you now need to check that the microphone is selected as your default audio device.
  14. To do this go back to CONTROL PANEL, followed by SOUND & AUDIO DEVICES
  15. Click on AUDIO and, under the SOUND RECORDING tab select your microphone from the drop down list.
  16. Then click the VOLUME button which will open a window called RECORDING CONTROL
  17. Make sure there is a tick (check mark) against microphone and that the slider is up at the top of the scale.
  18. If everything is okay up to this point the problem may well lie in the settings for the audio / recording program that you are using. Most programs have some sort of wizard for testing audio settings, which you will need to work through.
Posted on Jan 30, 2011
  • Jim McCune Jun 05, 2012
    Great writeup! Thanks for the help. I wrestled with a USB mike yesterday. If I plugged it into the adjacent USB port, it worked, but I had no idea why. I think I need to update my USB drivers to clean things up. Thanks again! Jim
Reboot problems
Hi Dear,
The problem you discussed is hardware related, IT has to do with the cmos battery or the Sata cable.
Disconnect/Connect CMOS battery and reconfigure BIOS settings again based on defaults
- Replace "ALL" SATA Cables and reconnect all drives
Regards
Samson Ved
Oct 18, 2013 | Gateway GT5670 Desktop PC
My brand new Samson Graphite MIDI Controler Keyboard hanging whenever i will save an edited data. i have to unplug the cable power or the USB cable to swicth it off and open again for me to use it. th
i have the same same problem with my unit, i really need help !!! The problem is still there , even if you do a firmware upgrade . i also returned the unit to the retail store and have a new one with the same problem, the software editor doesnt work on windows 7 but in windows xp with 1.92 version, please check my video
http://youtu.be/DKn5ArIxl4M
Jan 21, 2013 | Samson Graphite 49 - USB/MIDI Keyboard...
My Samson C01U microphone doesnt seem to be working. the green light doesnt turn on when i plug it into the usb port of my computer. I have windows vista. Is it not compatible?? The computer says the...
Sorry this isn't a solution but just letting you know I'm having the same trouble, the funny thing is mine was working a couple of months back and now its not, it's driving me crazy.
May 19, 2011 | Samson C01U Consumer Microphone
I got a 35 mm cable on my c01 and it won't work on my pc does someone know the problem..cuz when i put another mic in it just works fine
You Samson microphone requires phantom power to operate. PC's don't have phantom power. You need to run your mic thru a mixer that has phantom power.
Apr 14, 2010 | Samson C01U Consumer Microphone
I have connected the samson mic to my computer. input not detecte
A condenser mic. requires "phantom power" usually supplied by a mixing desk. Without this, there will be no output signal from the mic.
Jan 12, 2010 | Samson C01U - USB Studio Condenser...
Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
Pc wont turn on
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Also check the condition of the USB ports if it doesnt work and the fuse. If this doesnt work then I would recommend a repair.
Jan 19, 2009 | Computers & Internet
Samson C03 Microphone using with Realtek HD Audio Manager
SEU MICROFONE PRECISA DE UM RECURSO CHAMADO PHANTON POWER QUE NADA MAIS é DO QUE UMA ALIMENTAçãO DE 48 VOLTS, PORTANTO NECESSITA DE UM APARELHO INTERMEDIARIO, COMO UMA MESA DE SOM COM ESTE DISPOSITIVO OU UM ADAPTADOR PHANTON POWER COM SAIDA USB PARA O SEU PC, NO CASO DA MESA TAMBEM é NECESSARIO UMA PLACA DE AUDIO COM CONEXãO USB EXEMPLO UCA 202 DA BEHRINGER , PODES CRER Só ASSIM FUNCIONA E SOM é MUITO BOM.
Apr 06, 2008 | Samson C03 Professional Microphone
Connecting samson co2
The Samson CO2 is a condenser (also called capacitor) mic, and thus requires phantom power to operate. In order to apply phantom power, you must have a board capable of handling an XLR connection, and supply phantom power. Usually there is a switch located near the XLR-input jack on your board - if you post your sound board type, more help can be given.
Dec 16, 2007 | Samson CO2 Professional Microphone
Samson G-track - Vista requiring to install USB Audio Codec
If the LED doesn't light when you plug it in, and it doesn't show up in Device Manager ("USB Composite Device" or "USB Audio Device"), then the mic must be defective. Contact Samson for a replacement.
Nov 24, 2007 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson C01U Consumer Microphone Logo
855 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
