Tcl tv - have just lost the picture for win tv and related channels only still have the sound
Posted by greg223 on
John Sambell
    New Friend:
  • 3 Answers
Call TCL for a firmware update, which will fix the problem. They will send it out for free, along with a serial cable. You will need a PC or laptop with a serial (RS-232) port to perform the update.
The issue is that WIN, GO and GEM are broadcast on a frequency off-set by 125kHz from normal. TCL TVs cannot tune to xxx125kHZ, only multiples of 500kHz.
Posted on Feb 08, 2011
Sony DVD/VHS player to my TCL Roku TV
You can use the RCA style jacks, Yellow for video White for left and red for right audio OUT . Connect the TV end the same way. Note the source input number on the connectors of the TV. Turn both the TV and the Sony on. On the TV, select the input number the cables are connected to and you will see the Sony . If there are no unused places on the TV to connect to then take off the antenna/ cable wire off the TV and put it on the ANT IN connector of the Sony. Obtain a jumper cable wire long enough to reach the TV from the Sony and select either channel 3 or 4 whichever channel is not used in your area on the back of the Sony. Now turn both on and select TV as the source and put it on channel 3 or 4. Now turn off the Sony and change the channel on the TV to any other one in your area. If there is no picture, then the Sony will have to be on while watching TV.
Sep 15, 2016 | TCL 40FS4610R 40-Inch 1080p 120Hz Smart...
Tcl tv freez no sound/picture
are you using a cable box, tried to reset the box.
Oct 13, 2012 | TCL L32D20
TCL LCD TV L24D10F Channel locked; need password
how to upgrade my tcl lcd tv l24d10f? can u give me a firmware?
Oct 24, 2011 | Televison & Video
Only channel 9 no picture but got sound in LCD TCL BRAND
Make sure in the menu that you are using cable instead of antenna - then do a channel scan if you are using a coax and not thru a cable box. Have you tried any other inputs to ensure they are working properly? Please reply if you need additional assistance.
Thanks,
Michael
Feb 25, 2011 | Panasonic TCL42D2 42 in HDTVReady LCD TV
TCL tv- channel nine has no picture but sound? Can I fix it
I have exactly the same problem with my TCL HD television. Previously worked ok but no amount of rescanning the channels will restore the picture. :(
Feb 25, 2011 | Televison & Video
I have a TCL L42M61AZ LCD TV. I find that the "Channel 9" programs in Adelaide, Australia, namely GEM, GO and Channel 9 DTV will not show a visual picture, only play audio. All other programs are...
A firmware update from TCL will fix the problem. Call them and they will send out the firmware and a serial cable (required for update) for free.
I did the update yesterday and it fixed the problem (sound but no picture).
You will need a PC or laptop with a serial port (RS-232).
Jan 26, 2011 | Televison & Video
Tv tcl-14175 no sound on channels but ok on audio video mode
Hi
The first problem was always standby mode.... get back the original eprom IC 24CO8WP in to the PCB, then find the original remote control of you TCL Tv tcl-14175 then you power On In the Remote control while your TV is in Standby mode! then you see your tv is going ON... Because your unit is in Child lock Mode....
thanks!
Nov 21, 2008 | Samsung DLP HL-P5663W 56" TV
TCL tv
i have tcl satellite tv...the porblem is when i switched on , 5 or more minutes after, the tv unit shut off itself. Sometimes the tv scan its channels first before having picture then shut off after few minutes..varying time when shutting off.....And when using for video movies everything alright....please tell me what to do??...any solutions??..advance thanx to those who could help...
Oct 29, 2007 | JVC AV32F476 32" TV
Televison & Video Logo
1,173 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
