When I used chlorine bleach, it made large bleach spots on my bed sheets. The bleach was put in the bleach dispenser. This is very dissapointing as I like to use a small amount of blead n my light colored bed sheets and towels.
Fiona, could it be that your'e using Liquid color-safe bleach as it is thicker than chlorine bleach and will not dispense properly from the chlorine bleach dispenser?
And did you Remove the inserts from the drawer. The inserts are the detergent selector and covers of the softener and bleach dispenser.. and clean and replace them?
Tis really hard not being there and being able to see the unit.
But thought I'd give you these suggestions.
It is caused by mold being in your washing machine.Pour 1 cup or more of chlorine bleach into the drum in your washing machine and depending on the size of the washing machine and add 1/2 cup of liquid chlorine bleach into the detergent compartment of the dispenser drawer and fill the bleach dispenser compartment with chlorine bleach up to the highest level. Start the washer and let it do a full complete washing cycle.
The short answer to your question is YES! Clorox 2® Stain Remover & Color Booster has hydrogen peroxide as its active ingredient and is in the class of oxygen, color-safe (or non-chlorine) bleach. Compare this to Clorox® Regular-Bleach2 with CLOROMAX®, which uses sodium hypochlorite as it's active ingredient and is in the class of chlorine bleach. Hydrogen peroxide is safer to use in your dispenser than is chlorine bleach.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
1. Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Washer Monthly Maintenance Procedure: This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
remove any clothing or items from washer
CLOSE door (duh)
open dispenser drawer and remove the detergent compartment and set aside. No laundry products will be added at this time. You will be required to add only liquid chlorine bleach at a later step.
For Kenmore Elite HE products press a specific combo of buttons.
Select Rinse/Spin program
select low spin speed
select warm/cold water temp.
select 2nd rinse option
push the "end of cycle" signal button 4 times within 5 seconds to start the cycle
The machine will fill and run a short sensing cycle. This will take about 3 minutes.
Step 5
The washer will provide 4 short tones. Check the: ESTIMATED TIME REMAINING display for the codes indicated below:
if "Ab" (add bleach) displayed in the estimated time remaining window (you'll hear 4 short tones) proceed to Step 6.
if "rL" (remove load) displayed in the Estimated Time Remaining window an error tone will sound. The door will unlock. -open the door and remove the items from the washer. -continue the cycle by pressing the START button.
NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
6. Add liquid chlorine bleach.
If using the maintenance procedure for the first time, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the Main Wash detergent compartment. The liquid bleach should immediately flow out of the dispenser.
If doing a monthly maintenance procedure, open the dispenser drawer and immediately add 1/3 cup bleach to the Main Wash detergent compartment. The liquid chlorine bleach should immediately flow out of the dispenser.
NOTES:
Water will be flowing into the dispenser drawer when the bleach is added ... this is normal.
Do not add any detergent to this cleaning cycle. Use of more than 1 cup of bleachw ill cause product damage over time.
7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
