Cookrobert- you have to determine wich wire is the common wire in the box (house). Look in the box and see wich two wires ore in the same sleave. (These will be your travelers, (more than likely a black and a red) the wire that is in its own sleave (black)with a white tied to other whites is the common. Now the dimmer will tell you wich wire is commom. Tie the tow commons together. The green wire is ground if your house does not have ground , cap it and forget the green, if your house does have a ground (bare copper wire) then connect the green to the bare wires is the house box. Now your to travelers on the house side will tie to the two travelers on the dimmer side. Once you have found the traveller's on the house side and dimmer travelers they can be flip flopped. It dosnt matter. Just as long as they are the traveller's it will work. It sounds complicated but I'm sure you got this. I'm a 30 year electrician. (master).. I'll be looking for your update my friend. Good luck
NOTE: The blower motor is located on the passenger side of the vehicle under the instrument panel. The blower motor can be removed from the vehicle without having to remove the HVAC housing.
Disconnect and isolate the negative battery cable.
Pull back the carpet to access the front upper screw that secures the air inlet housing.
Remove the recirculation door actuator.
Remove the recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside.
Disconnect the blower motor wire lead connector from the blower motor resistor or power module, depending on application.
Lower Air Inlet Housing
Remove the one screw (from the top) that secures the lower air inlet housing to the upper air inlet housing.
Remove the four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing.
Blower Motor Wire Lead Grommet
Push the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
Feed the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
Position the recirculation-air door as necessary to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
Gently flex the recirculation air door far down enough to remove the blower motor and wheel from the HVAC housing.
Blower Motor Mounting Tabs
Remove the blower motor and wheel from the HVAC housing. Note the position of the blower motor mounting tabs.
The wires come out with the switches. Usually when you purchase a set of chrome switch housings, you swap your switches from the old housing to the new housings. If you bought the chrome housings with the chrome switches, you have to connect your original wires to the new switches. When you take the two bolts out that holds the switch housings together, the wires will come out of a slot that they run through.
the wiring plug is their if you look for it ,slacken teh door panel a bit and pull the wires ,look on the new one for length of the wires to work out where the connection is ?
Blower MotorRemoval & InstallationFrontTo Remove: NOTE: The blower motor is positioned on the passenger side of the vehicle beneath the instrument panel, and can be removed from the vehicle without removing the HVAC housing.
Before servicing the vehicle, refer to the precautions at the beginning of this section.
Remove or disconnect the following:
Negative battery cable
Passenger side cowl trim panel
Carpet to access the front upper screw that secures the air inlet housing
Recirculation door actuator
Recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside
Blower motor wire lead connector from the blower motor resistor or power module, depending on application.
One screw (from the top) that secures the lower air inlet housing to the upper air inlet housing
Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing
Feed the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
Push the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
Place the recirculation-air door as needed to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
Lightly bend the recirculation air door far enough down to remove the blower motor and wheel from the HVAC housing.
Remove the blower motor and wheel from the HVAC housing. Make a note of the location of the blower motor mounting tabs.
To Install:
Install or connect the following:
Blower motor and wheel to the lower half of the HVAC housing and line up the blower motor mounting tabs to the correct location on the HVAC housing
Blower motor and wheel into the HVAC housing by lightly bending the recirculation-air door far enough down
Three screws that secure the blower motor to the HVAC housing by positioning the recirculation-air door as needed
Torque to: 17 inch lbs. (2 Nm)
Blower motor wire lead through the opening in the lower air inlet housing and seat the rubber grommet into the lower air inlet housing
Recirculation-air door pivot into the lower air inlet housing
Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and the lower HVAC housing
Blower motor wire lead connector to the blower motor resistor or power module, depending on application
Recirculation door actuator wire lead into the routing clip located on the lower air inlet housing
Carpet
Perform the heater-A/C control calibration procedure.
RearTo Remove: NOTE: The rear blower motor and blower wheels are repaired only as a balanced unit. The entire blower motor and wheel assembly must be replaced if either component is fault or damaged.
Front center floor console cover
Rear Blower Motor Housing
Body wire harness connectors from the rear blower motor power module and the rear mode door actuator
Body wire harness bracket from the console support bracket
Eight screws and the two console support brackets from the floor console base and duct assembly
Four screws that secure the rear blower motor housing to the floor console base and duct assembly
Rear blower motor housing and place it on a bench
Rear blower motor wire harness connector from the power module
Eleven retaining clips and three screws that secure the housing together
Two halves of the housing
Blower motor wire harness and grommet from the housing and remove the blower motor
To Install:
Rear blower motor into the housing and install the blower motor wire harness and grommet
Two halves of the rear blower motor housing and install the eleven retaining clips and three screws
Rear blower motor wire harness connector to the rear blower motor power module
Rear blower motor housing into the floor console
Two console support brackets onto the floor console base
Eight screws that secure the support brackets to the floor console base
Body wire harness bracket onto the console rear support bracket
Body wire harness connectors to the rear blower motor power module and the rear mode door actuator
When dealing with older houses, you run into this a lot, but the somewhat newer houses will actually have the 3 wires to hook up the ceiling fans. You can still use your 2 wires, but you will have to double up the motor and light wires. Wire nut the Black and Blue wires together with your Black wire from the house, and the White wires will be tied together for your neutrals. You should also have a green ground wire also, be sure to hook that to a ground in the house too. Hope this helps!
if you have220/240 across the house black wires put red from stove to one black then black to blackaluminum to copper should be the ground turn breakers off after you check the volts across the black and the ground make sure the ground is a ground and you will need to run a white wire back to the breaker box for the neutral then white to white
What do you mean and what do you want to do?
