Question about DISH Network IR Remote Control
The inlaws pushed about every freaken button on the remote,now the picture on our tv is way too big ,and the heads and logs etc are no longer there help !!! please
Anonymous
    Scholar:
    New Friend:
  • 24 Answers
This formatting issue can commonly be corrected by simply pressing the (*) button on your remote this button is also known as the format button and is located in the bottom left corner of the remote, which is also to the left of the zero button. You can change the formatting of the tv picture by pressing the star/format button until the format is corrected. I hope this helps!
-Kirstie DISH Network
Posted on Jan 30, 2011
How do I change aspect ratio through onkyo receiver
You should have on your remote a button to change picture 4/5, 9/16, ZOOM 2xZOOM etc... If you don't have a remote, some menu functions can be accessed through buttons you may find along the border of theframe of your TV
Jul 26, 2015 | Onkyo TX-NR818
No picture just blue screen
Check your settings button. Most remotes have a video source button...if this button has been pressed, then the tv is probably trying to show you the video screen. On my remote, pushing the button 3 times brings it to the dvd screen. Pushing it twice brings it to cable tv...etc.
Your button may be labelled as something other than video source.
Nov 03, 2013 | Televison & Video
I need a code for my remote
What is the Brand name of your TV?
Oct 07, 2012 | Big Button TV Universal Remote
Picture on screen is too big head of people are cut off it does not show complete picture
Use your cable or satellite tv remote to adjust the aspect ratio. If you have cable there is a button on the remote called hd zoom and it has this symbol: #. On the satellite tv remotes it usually says format or aspect. You might even have to go into the cable box/satellite tv receiver menus to adjust the aspect ratio/picture format. Once you have done so you can fine tune the picture even further with the television remote's wide/format/aspect/zoom button. Also check and make sure your television is on the right input and that your cable box/satellite tv receiver is set at the right resolution for the television 1080p/1080i/720p.
Jul 12, 2011 | RCA HD52W59 HDTV Projection Television
Picture has become too big for screen
Used ur tv original remote,look for a button like View Mode,Picture Size,Aspect Ratio,Zoom.Pushes one of these buttons to changes the picture sizes to fit ur tv screen.
Jun 05, 2011 | Toymax Skyworth SLTV-2663A 26 in. LCD TV
When I turn on TV I get a message no video input. We never use video with this tv. Only have it for looking at satelite. The other main tv is working fine. I pressed all the buttons but nothing works.
Sounds like the input accidentally got changed. On the remote that came with the TV, push the INPUT button until you get your satellite picture again. If your SAT. remote is programmed to your TV, push the TV button, then the input button until you see your picture. If this doesn't work then the sat. cable is not securely attached or no longer works.
Aug 30, 2009 | Philips Magnavox 27MS343S 27" TV
Picture too big for screen
on your remote push the arrow key to the right or left side. this should change format and go into customer setup and turn of autoformat
Aug 31, 2008 | RCA HD52W59 HDTV Projection Television
RCA 52inch Big Screen.
On your remote push "Info" then push right or left to get OFF zoom mode, Cinema view looks pretty good.
Jul 20, 2008 | RCA HD52W56 52" Rear Projection HDTV
Big button remote rcr 4258
does not have all the codes for every product,
Please give me the model # for the cable box -scientific Atlanta and the model # for Magnavox T.V.
also goto www.replacementremotes.com (336)969-1842
They will find you REPLACEMENT remote control CODES, not remote control
Apr 12, 2008 | RCA Universal Remote Control
DISH Network IR Remote Control Logo
147 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
