Motorola Mobility W375 Cellular Phone Logo
Posted on Jan 29, 2011
I insert my sim card in the phone and when i put it on ,it says insert sim
2answers
Insert sim card
I'm not sure what the question is you are asking concerning a "sim card" but if it's How to put a SIM card in your cell phone you need a pin to put in the hole and it will pop open, However if your question is that your phone keeps telling you to insert a SIM card then you need to turn off your phone first and then go into the place where it's at and remove the SIM card and then put it back in and then turn your phone back on.
2answers
How can i put sim card on my cellphone
the back of your phone and under the battry and bam there it is put your sim card right in the sim card hole
3helpful
Even I inserted the sim card phone shows Insert sim card?How to solve it?
Well it is either a problem with the SIM card or the phone. First you should test out your SIM card.
Put the SIM in a friend's phone. If you put the SIM card in this other phone but it still says insert sim card, then it is the SIM that is no good. If the SIM works fine in the other phone, it would be the phone that is the problem.
May 07, 2011 • Cell Phones
3helpful
I put the sim card in and it says insert sim card
Hi, when a phone says insert Sim,is either the Sim card or the Sim seater that allows the Sim to work is bad.
First try the Sim card on another phone and see if it will display insert Sim again.If it display that means the Sim card is damaged. But if no display,that means the Sim tray of your phone is damaged and will need to be replaced.
Contact a skill prsonnel.
Take care.
3helpful
2answers
When i am inserting my sim card in phone,the phone...
this can only be if the Sim card is not put correctly or the Sim card is short from inside or the Sim card slot of the phone is damaged!!try some other Sim card!
8helpful
2answers
Insert sim card issue
just insert another sim card and check whether that sim card is working. also put your sim card in to another phone and check whether it is working.
''Please insert SIM card''
th sim card needs to be unlocked or its not compatable with the phones you putting them into.
1. unlcok the sim card by calling your provider
2. the phones needs the unlock code as well.
thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 • Cell Phones
4helpful
5answers
Cect P168 not dectecting My sim Card
The "insert sim" error is a common error. Usually it is caused from putting the sim in incorrectly.
Try this. If this is the one with the sim card ports that are on top of eachother than put the sim card in the port closest to the phone with the gold side pointing up.
Insert battery, turn on phone.
On the phone, go to the main menu. Tap phone settings. Tap dual sim settings. Tap to open sim 2. Go back to the main screen.
If that does not resolve go back to phone settings, tap dual sim settings, tap to open sim 1, go back to the main screen.
If this is the type of phone with the sim card ports seperate, insert sim with gold side down in either port. Go to phone settings, tap dual sim settings, tap open dual sims. Go back to main screen.
If this problem persists than either the phone or the sim is defective. Test the sim by putting it in a phone that belongs to the carrier the sim came from. If it works in that phone it is not the sim.
2helpful
2answers
Insert SIM Card
make sure the sim card can make good contact with the phone.
Also check if it doesn't have space to slide, causing it to loose contact with the phone.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
