Question about Kohler Electrical Supplies
I have a Kohler Confidant 5 LP unit that was running great. Now nothing. It cranks great but will not start. It has spark and the fuel sol. is working, but can not tell if it's getting fuel. Can smell it but can't tell if it's getting into the carb. It does have compression too. Any thoughts would be helpful
Posted by fran_mary on
Lisa Whitaker
    New Friend:
  • 26 Answers
Drain the fuel and replace with ethanol free gas
Posted on Dec 29, 2017
3 Related Answers
jdthefixer
  • 746 Answers
SOURCE: 15 HP OHV Kohler engine with no compression
Have you checked for a bad head gasket?
Check the intake valve springs or the intake valve shafts to be sure they aren't stuck open. Another cause could be excessive carbon build up on the intake valve causing them to not seal.
If you've gone this far, you could try a compression leak down test. If you still have the push rods out, you can use or get an adapter that will allow you to pressurize the cylinder(s) with air by removing the spark plug. Apply 70-80 psi air directly to the cylinder (the cylinder may go to BDC (bottom dead center) but if you don't have any push rods, the valves can't open.
Listen carefully - if you hear air leaking out of the carb, it's a bad intake valve. If you hear air from the exhaust, it's an exhaust valve. If you hear air from the crankcase breather, it's piston rings.
Posted on May 03, 2009
Anonymous
  • 3 Answers
SOURCE: My Kohler Confidant IV generator starts and runs
Kohler generators feed the generated voltage back into the control circuit board to tell it to keep the fuel pump (electric) runing and the ignition on. IF there is no voltage generated (bad brushes or?) then the symptom you describe will occur. The motor runs fine, but it isn't generating electricity.
Jim Russell
Posted on Jun 15, 2009
Fred Yearian
  • 5603 Answers
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Posted on Aug 11, 2009
HOW DO YOU REMOVE FULE FLOT BOWL KOHLER CONFIDANT 5 5CKM21
It is not a float issue because the motor cannot consume the entire contents of the gas chamber in one instance of a surge. This is a throttle issue.
Oct 05, 2015 | Kohler Electrical Supplies
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Dec 05, 2012 | Kohler Electrical Supplies
Kohler Confidant 4 puts out to much voltage
Are you running the gen and plugging in the RV at the same time? I assume it is wired right and you have a transfer switch? Are you saying the voltage is fine when the RV isn't plugged in?
Apr 15, 2012 | Kohler Electrical Supplies
93 honda del sol will turn over but wont start. It has a new time belt, distrib, and the main relay works.
Is it not getting spark or gas? It needs both to run. Both main source. If no spark in any cylinder, then ignition module or crank sensor is likely faulty. If no gas, then fuel pressure regulator or fuel pump or fuel pump relay is bad.
Nov 11, 2009 | 1990 Honda CRX
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
Aug 11, 2009 | Electrical Supplies
My Kohler Confidant IV generator starts and runs great for about 30 seconds and then dies,, starts right back up and does same thing, what is up with that
Jim Russell
Mar 30, 2009 | Electrical Supplies
Electrical Supplies Logo
254 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
