Question about Andis Styliner SLII Hair Trimmer
Andis t blade; my motor is working but the blades wont move
Posted by riconorth1 on
3 Related Answers
heidi muehlenberg
  • 62 Answers
SOURCE: my andis clippers are experiencing
Have you kept the blades oiled well both before and after every use? If so then the next step would be to send the unit in for repair. Please call the Andis customer service department at 1-80-558-9441 to either find a repair station in your state or to get the factory address.
Thank you for choosing Andis.
Posted on Nov 13, 2008
Anonymous
SOURCE: My GTO model Andis clippers
YOU HAVE TO OPEN DEM UP. TAKE OUT THE SCREWS ON THE TOP DEN TAKE OFF THE BLADE. ONCE YOU HAVE THE BLADE OUT THERE ARE TWO MORE LIL SCREWS UNSCREW THOSE (NOT ALL THE WAY OFF, JUST ENOUGH SO THAT THE BLADE WILL MOVE) ADJUST THE BLADE HOWEVER YOU WANT. IF YOU WANT IT CLOSE FOR A MORE DETAILED CLOSE LINE (NOT TO CLOSE AS DEY WILL CUT YOUR OR THE CLIENTS SKIN). YOU MUST TRY THEM OUT ON YOURSELF SEE IF THEY ARE TOO SHARP, IF THEY ARE TAKE THEM OFF AND ADJUST THEM AGAIN. EASIEST THING TOO DO IS USE A MIRROR, HOLD THE BLADE AGAINST THE MIRROR DEN MOVE IT AT AN 45 ANGLE DEN TIGHTEN THE SCREWS DER (BARBER TRICK).
Posted on Jul 21, 2009
Anonymous
  • 8 Answers
SOURCE: adjust blade
On the Andis T-Outliner or Outliner if you have use the trimmer for more than 3 hair cuts or 3 time or more I do not recommend moving the blade, reason why is that you have all ready start or have a sit in or a grooved, I have found that by moving the blade it won't cut at all.You need to resharpen the blade with a professional sharpener and have them reset the blade for the type of hair cut you want. The blade can be set to shave or do line ups, and Fades. This type of trimmer is for that kind of hair cut the professional barber use them all the time. Call Mannys Sharpening 323 263-4697 They have a good rating on Yahoo Local.
I have try many sharpener and had no luck, until a friend of mind told me about Mannys Sharpening, They know what they are talking about highly Professional in thier work.
Posted on Aug 01, 2009
Have used my brand new Andis Excel clippers for 3 weeks. after a couple day started having trouble with clippers not wanting to turn on or they would come on but cut on and off several times before working...
install the clipper blades onto the unit properly
read the user manual on how to do it
From your description it indicates that the blade base is on the tang but the clipper is not inline with the activator and will click in a bit more
Mar 08, 2018 | Andis Health & Beauty
Hi; i just bought a andis improved master clipper and the blades stop working right after i tried to adjust the voltage ,i can hear the motor running, but the blades don't move, please help me! thanks!
I just had this same problem. My andis Masters where working and they started making a loud sound and the blades stopped working. The Problem was there wasn't enough power. I used a screw driver and turn the power adjusting screw to the Right with a flat head screw driver.the sound got louder but after I keep turn it the blades started moving again and the blades got quiet again. Tada a Quick Fix.
Dec 26, 2010 | Andis Improved Master Hair Trimmer
Using T-84 Andis blade for horses and cutting
Check the two screws either side of the hinge assembly make sure they are tight, the problem appears to be with the clipper if all blades do the same.
Jan 16, 2010 | Oster Golden A5 2-Speed Universal Motor...
Want to adjust trimmer so i give a better outline i just bought new blades, not sharp enough
Sometimes the new blades are not sharpen enough, You need to have it resharpen by a professional and adjust to the type of work you want it to do. Also sometimes even if you have the blade resharpen it will not cut, because the trimmer motor needs more power to move the blade side to side faster. On and the Andis GTO T-outliner trimmer this the most comm problem. Try Mannys Sharpening
Jun 15, 2009 | Andis Outliner II Hair Trimmer
I have a andis outliner 2 and it was working fine then i took the blade off to clean it then whten i put it back togather it wont cut like befor, blade does not vibrate like before.
The blade has not been lined up correctly when it was put back on. For complete instructions on how to replace the blade please visit the Andis website at www.andis.com. Click on the service tab and then use and care. Scroll down to the model you have and click once more. If you need any additional help please call the Andis customer service department at 1-800-558-9441.
Dec 11, 2008 | Andis Go 04630 Outliner Beard Trimmer
Andis T-Outliner
adjust the brown plastic on the blade all the way up.remov the blade and the brow plastic is held with screws
Apr 23, 2008 | Andis 04603 Hair Trimmer
Andis Styliner SLII Hair Trimmer Logo
308 people viewed this question
Top Andis Health & Beauty Experts
Bruce Showalter
shaveroutlet.com
shaveroutlet.com
Anthony Ward
Anthony Ward
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
