Question about Ricoh Aficio SP C820DN Laser Printer
How to open front cover for ricoh aficio c820dn printer as it is displaying message " open the front cover to check the paper jam"
Posted by das_chitharn on
Benjamin Jr Singson
    Genius:
  • 1,570 Answers
Hi there !
You have to open the front cover means that you have to oper the toner compartment and check for the paper jammed inside.
Did it helps your or you find the paper jammed.
Posted on Jan 29, 2011
How to remove paper jam from duplex unit
No issues i share a informative links please visit and read it.
Read more help... How to fix printer paper jam andHP Printer Support
Thanks,
Aug 26, 2014 | Ricoh Aficio SP C820DN Laser Printer
Paper jam c
Unable to print troubleshooting and routine maintanance chapter in user's guide
Mar 23, 2013 | Ricoh Aficio SP-C210SF Printer
Cover open reset
Verify the cover actuators and switches,cover reset don t exist.
Feb 14, 2013 | Ricoh Aficio SP C820DN Laser Printer
Ricoh SPC400DN Getting frequent "Press A
It sounds as if it is not picking up the paper from the tray. It might need new feed rollers. Another thing to check is the lift arms on both sides of the tray. Make sure the springs are still attached to them. There is also a little switch on the left side front of the tray that adjusts the bottom plate pressure. You can try adjusting that to see if it helps.
Mar 12, 2011 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
My new Ricoh C820DN printer gives me a "waiting
please DO NOT use PCL printer drivers. USE RPSC or PS (post script) drivers and everything will be OK
pifonski
Feb 24, 2011 | Ricoh Aficio SP C820DN Laser Printer
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
Printer keeps saying it has a paper jam and to remove the jam from the back. There is nothing there! I think it just wants me to open and close the rear door, but that only fixes it sometimes. How do I...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 22, 2010 | Ricoh Aficio CL1000N Printer
MACHINE DO NOT COPY AND GIVE THE FOLLOWING MESSAGE: (A ZIGZAG SYMBOL) WITH "FOLLOW THE INSTRUCTION"
Sounds like the 'Clear misfeed' symbol. Open the front cover and follow the pictorial diagram instructions to check your paper feed path for jammed paper. Remove misfeed, and close covers. This should reset your machine.
Jan 30, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
Jan 30, 2008 | Ricoh Aficio AP2000 Laser Printer
Ricoh Aficio SP C820DN Laser Printer Logo
363 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
