Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
The ice/ water machine not working - Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Posted by buttergirlbl on
Kelly
  • Whirlpool Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
When both the ice and water in door functions stop the problem is usually the door switch. If the door switch fails in the open position the light stays on when the door is closed and water and ice in door do not work. With the door open depress the door switch plunger to see if the comparment light goes off. If it stays on the door switch has failed. If it goes out.. hold the door plunger depressed and have someone try the water in the door. If the water in the door now works the door switch is not getting depressed enough to allow the water and ice in door to work during NORMAL operation. Again usually it requires door switch replacement to correct the problem. The door switch is a 3 terminal switch. One terminal is common, One terminal controls the light, and One terminal controls the water and ice in door functions. The switch retails for less than $10.00
You remove the switch by sliding a thin knife blade along one side of the switch to release the single locking tab. You can use a putty knife also.
Since you did not include a model number I can not help you with parts data.
There is more that can be done if the door switch is ok but I really need the model number to proceed from here. I will help you... Just respond with a COMPLETE model number.
Thanks for choosing FixYa,
Kelly
Posted on Jan 29, 2011
Whirpool ice machine not getting water
If your certain the line isn't frozen. Then your valve is bad
Apr 20, 2015 | Whirlpool Refrigerators
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
Jan 23, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice machine not getting water
Change the dual water control valve if not getting water during cycles.
Sea Breeze
Jun 08, 2012 | Kenmore Refrigerators
Ice maker is not working
ok one of the first steps is to make sure your getting water inside the ice maker feel with one of your fingers if you can feel ice or water on the inside of the tray if you have ice then you would have to disconect and remove the ice maker fromthe machine and run hot water to clean out the ice build up on the inside then reinstall the ice maker back into the machine and test for 24 hrs to see if you get ice if you dont then you have to replace the icemaker. If you do not have any water going into the icemaker water tray then you would have to check the water valve located in the rear of your machine if the water valve is not bringing water to the icemaker replace the water valve hope this helps
Jul 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Can't control the Temp. too cold/Ice-Machine over flow
sounds like you have a sensor problem or a open damper ,staying open,so it keeps freezing in the frig...call if need more input...michael..doctor airr appl.repair..843-384-8474...
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker is working, but there is water in the bottom of bin
You will need to pull out what ice you have in the bin to get to the drain. Once you have done that, take a hose and force water thru the drain. You may have to snake the drain if is more than a build-up of ice. Once the drain is working, clean out the bin with ice machine cleaner and sanitizer. Restart the machine and make sure no water is dripping from the evaporator above. If there is, it needs to be cleaned.
Nov 07, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Whirlpool Side by Side Refrigerator Model # ED2FHEXNQOO
POSSIBLE YOU HAVE 2 SEPERATE WATER SOLENOIDS. THE SOLENOID FOR THE ICE MACHINE HAS A STRAINER AND ORFICE JUST INSIDE THE INLET SIDE OF THE WATER CONNECTION. CAREFULLY REMOVE THE ASSEMBLY AND CLEAN-IT. YOU CAN CHECK IF ICE MACHINE SOLENOID HAS POWER BY TAKING A METAL BUTTER KNIFE AND HOLDING IT JUST ABOVE THE COIL ... THE MAGNETIC FORCE SHOULD BE FELT TUGGING THE BLADE DOWN. LOSSEN THE NUT ON THE OUT-LRT SIDE OF THE ICE MACH. SOLENOID AND SEE IF YOU HAVE WATER ...
Apr 26, 2007 | Whirlpool GD2SHGX Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
165 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
