Question about Koss Audio Players & Recorders
I have the HG1505 Koss digital player.... 1. I turned the button to cd and it will not spin unless I turn it off and on again then it only spins a few seconds. No sound... In the window, it says 00:00 and track 00 then switches to a flashing disc. I' m not famaliar with disc players... Am I doing somethng wrong? What can I do to get it to spin and have sound on it.?
richie46
    Top Expert:
  • Koss Master
  • 12,962 Answers
The player is no longer any good. Sorry.
Posted on Sep 08, 2017
5 Related Answers
Anonymous
  • 108 Answers
SOURCE: KOSS CD player will not read CD says '' no disc
1.Your Disc might be damaged
2.Your cd player laser beam reader lens might be weak or dead
3. Check whether it happens to all Disks
4. if it does not play all the disks then you have to change the laser diode lens assemble.
5. contact service centre to fix news lens
Posted on Dec 22, 2007
Anonymous
  • 85 Answers
SOURCE: CD player does not play discs
Laser has died ,problem with pioneer is laser costs are ridiculous and write the machine off
Posted on Jan 08, 2009
Anonymous
you need to Clean the laser lines inside the cd player I can do that for you if you want me to
Posted on Apr 02, 2009
Anonymous
  • 6784 Answers
SOURCE: CD player WILL NOT PLAY and does not recognize CD presence
HI. this is optical lens assembly failuer. the optical lens is burned out, in return, inducing the (no CD) message. simply replacing the optical lens assembly will fix this issue.
Posted on May 27, 2009
Testimonial: "have same problem..solution sounds great...the only thing now is where can one obtain the optical lense replacement..no help from radio vendor"
richard3121
  • 3 Answers
SOURCE: Arcam CD73 CD Player. CD player works fine but sound cuts out.
I too had this problem and was resigned to having the laser mech replaced.............BUT! i opened up my unit (it was long out of warranty) and was suprised at the amount of lubricant on the cog that drives the laser and the track upon which it runs.most of the grease had been pushed to either end of it's travel and as a consequence my unit would cut out particularly at the start and end of CD's as the laser struggled to move and track the disc as it should. Since removing this excess lubricant (with a dry toothbrush) i have enjoyed over six months of trouble free listening. From searching online forums it would seem that many people have experienced similar problems with this transport - a Sony KSM213CCM - and have replaced the entire mech! it would appear that someone a the factory has been a little over enthusiastic with the lubricant! Hope this fix is of help
Posted on Aug 08, 2009
1helpful
How do I hack my Region 1 DVD player so I can play DVDs from other regions?
Some Koss players are locked to only one region/zone so this might not work. Try this.
  1. Turn on the player (without a disc inserted)
  2. Press MENU
  3. Press 1, 6, 7, 1, 9
  4. A menu should pop up
  5. Press OK
  6. Press the button for the desired RC (0=code free)
  7. Exit menu
I have purchased a vintage magnovox AZ9855 boombox .tape player and radio work fine. CD player displays DEF and doesn't respond at all .turning off and on at times says start then DEF.
If a CD player doesn't work there isn't much the user can do - putting in a disc the mechanism should be heard to spin; if it doesn't spin the process will go no further and it is a task for the repair shop.
If the disc does spin the laser will try to read the disc and if it fails it will be worth cleaning the lens but again if that doesn't work the repair shop beckons.
I have never seen the DEF message and don't know what it means unless it is an abbreviation of defective...
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Re KOSS KS4110 DVD player
I have HTV with cable.I can not get this Dvd player to work with remote or with out.I hear the CD and Dvd spin but nothing else.What needs to be done?
2helpful
2answers
Koss KD365 DVD - Says No Disc
Make sure the disc is spinning. This might sound crazy but try turning the whole player upside down and see if it plays.
1helpful
2answers
DVD Player turns on spins says reading but there is no picture or sound.
I had same problem and once left the player on for 3 weeks (left for vacation) and it still never worked. Finally had to dissassemble body of player to get dvd out. There appears to be no solution to this problem. I have called it quits and this cheap piece of junk is now in the trash. Koss will never be on my list of best buys.
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Marvin
Marvin
 Grubhead
Grubhead
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
