Question about GE Spacemaker JVM1640SJ Microwave Oven
Turned it on to heat food and make a loud noise , did not heat food and have electrical short ordor.
Posted by charlotte647 on
nick hunt
    Sergeant:
  • 186 Answers
There is something metal inside that is causing this look for any screws or anything that may have been switch with a repair. what happens is the metal causes the microwaves to reflect back to the magnetron instead inside the food causing noises and sometimes sparks and odor. find the metal object remove it and this should solve your problem
Posted on Jan 29, 2011
Making loud noise when turning on to heat.
If there's a loud noise when you try to microwave food, then the current through the high voltage transformer is probably too high.
Most likely, this is being caused by failure of a component in the high voltage circuit. The most likely component is the high voltage rectifier, followed by the magnetron or high voltage capacitor. High voltage transformers occasionally do burn up as well.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
May 27, 2016 | Microwave Ovens
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
Does not heat-has a louder noise
most likely you have a bad magnetron on unit... if everything else is working just not heating the magnetron is bad and this is what heats the food... it is located behind the control panel /.....sometimes there is a thermal fuse on the magnetron that can go bad but if it is making a loud noise most likely it is trying to come on but has shorted out....good luck to you./
Jan 12, 2011 | Microwave Ovens
My Frigidaire microwave is less than a year old. It is making a loud noise while running. So it runs loudly but does not heat up food. Is there a simple fix or did I get a dud?
The symptoms of loud noise and no heat indicate a short in the magnetron or high voltage diode. Need to take it to a qualified repair, to figure out what the problem. The magnetron replacement can cost as much as a new oven. See what the warranty covers, maybe you might luck out.
Dec 07, 2010 | Frigidaire FGMV174K Microwave Oven
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
Danby microwave does not heat food and makes loud constant noise
IF the noise is a sound coming from the oven area, its the megatron tube. Typically, replacing the megatron tube is more expensive than replacing wiht a new unit and a new warranty.
Nov 06, 2009 | Danby DMW112 Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I was boiling water on the electric range beneath my FRIGIDAIRE FMV157GC 1.5 Cu. Ft. Microwave Oven when there was a loud snapping/popping noise occured. I immediately shut off the microwave and thought...
I would say the transformer for the power supply has probably shorted, or another major component in the power supply has shorted - This may be repairable if easily spotted, but most likely will not be cost efective.
Sep 04, 2008 | Frigidaire Microwave Ovens
How do I fix a Jenn-Air JMC7000 that does not heat up items?
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Jan 06, 2008 | Jenn-Air JMC7000 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
129 people viewed this question
Top GE Microwave Ovens Experts
Jimmy
Poppa Maddo
Poppa Maddo
gbob59
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
