Question about Razor 300001-SL Ground Force Go Kart
When I turn the switch on after charge, it blinks on and off and my son can not use the gas feed on the steering wheel. The power switch blinks on and off.
Posted by richard_laug on
derik purlee
    Scholar:
  • 110 Answers
Hi, a blinking red light ,is telling you that a battery is going bad or you have a bad plug , or your charger is going bad .
I had a razor scooter that had the blinking red light, it was a busted plug on the scooter where it plugs in.I had one scooter that had the blinking red light, it was A battery gone bad .
good luck!
Posted on Jan 29, 2011
88 chevy celebrity right turn signal doesn't blink and the horn doesn't work?
check the bulbs most likely one is burned out .... that will cause light to not bilnk
Apr 28, 2014 | 1988 Chevrolet Celebrity
Power steering doesnt turn, is it my power steering switch???
Hi Chris, the concept of power steering in cars and trucks should read POWER ASSISTED, this means if your power steering fails, you can still steer the vehicle unlike some machinery and tractors that have full power steering which the steering wheel will just spin when the engine is turned off with no connection to your wheels, If your steering wheel does not turn it is a mechanical problem, steering arm jammed pitman arm in the wrong position or something like that. remove the pitman arm off the steering box and see if it will turn. you did mean that it won't turn at all and not turn easily like power steering should
Jan 04, 2014 | 2001 Chevrolet Tahoe
Remove steering column
why not say reason.. ??? is the actual shaft bad,
or just swapping out the whole thing.> with igntion switch and combo switch?
the whole inside parts?
are you removing the steering wheel ?
first hard part is air bags, very dangerous.
and the coil spring, in wheel hub. easy to damage that.
first off major work , you need the FSM. why not get it and read it.
if no bags , good. easier.
the other issue is the
there are 3 critical steps.
1: Bags.
2: ignition switch assy, anthieft screws.
3: collapsible shaft, possible damage.
4: the steering wheel puller and steps. the FSM covers each separately.
wheel. quote
  1. Disconnect the negative battery cable and disable the air bag system.
  2. Set the front tires in a straight-ahead position.
  1. Remove the air bag module retaining nuts from behind the steering wheel.
  2. Remove the air bag module. Defeated first !!!!
  3. If equipped, remove the cruise control switch.
  4. Disconnect the horn wiring.
  5. Remove the steering wheel retaining nut.
  6. Scribe a line mark on the steering wheel and steering shaft if there is not one already.
  7. Remove the steering wheel using a suitable puller.
  8. the palm smacking trick can get the wheel off if lucky.
To install:
  1. To install, align the scribe marks on the steering shaft with the steering wheel.
  2. Ensure the wheel compresses the 2 locktabs on the clockspring.
  3. Pull the air bag and if equipped, cruise control wires through the larger hole and horn wire through the smaller hole. Ensure they are not pinched.
  4. Install the steering wheel nut and tighten it to 45 ft. lbs. (61 Nm) while forcing the steering wheel down the shaft with the nut.
  5. Connect the wire feed to the horn buttons.
  6. Connect the feed wires and tighten the air bag retaining nuts to 90 inch lbs. (10 Nm). Ensure the air bag is completely seated. The latching clip arms must be visible on top of the connector housing on the module.
  7. Enable the air bag system and connect the battery cable.
  8. From the right side of the vehicle (in case of accidental deployment), turn the ignition switch to the ON position.
  9. Check for proper air bag warning light operation.
end quote, get the FSM. there are many more pages, for
the COMBO section, and shaft.
Nov 16, 2013 | 1991 Jeep Cherokee Limited
1994 GMC Safari Steering Wheel wont turn
Power steering pump might be out, Check fluids in the power steering fluid resivor, Should say steering fluid only,
Aug 23, 2012 | 1994 GMC Safari
Have a Hobart Beta-Mig 170 Wire will not feed
First make sure the nozzle tip is free of any debris and the wire will slide easily. Lift the case and go to the wire feed unit. Loosen the pressure nob then lift up to release the pressure wheel. Make sure the bottom wheel ( should have two grooves, one for .35 wire and the other for 025 wire.) Make sure the Wire Feed Tip is also free and it allows the wire to pass through. Pass the wire through the feeder across the drive wheel and into the hose. Allow the pressure wheel to drop, then lift the pressure know to the upright position. Turn clockwise to put tension on the wheel. Make sure the gas is OFF, turn power on, depress trigger switch. This should allow the wheel to turn and feed the wire.
Feb 25, 2010 | Hobart Welding Tools
Changing turn signal switch 1986 lincoln town car.
Get a manual like chiltons or haynes to guide you through this one...Air bag needs to be disabled and yes, wheel needs to be removed.You will need a wheel puller and a tool to remove the steering lock plate. The arm either unscrews from or is screwed to the switch...either way, it's removable.
May 29, 2009 | 1986 Lincoln Town Car
98 ranger locked in park,ignition key won''t turn to start
there is a harness that feeds the ignition remove your steering wheel cover and you will see about a dozen wires going into a clip that is attached to the back of the steering wheel , those wires give way and are not making contact reach in to the back and pull the harness forward and then try and push each wire back into the clip try this and see if it works it solved my problem basicly it is just a loose wire in the harness,,
Jan 13, 2009 | 1998 Ford Ranger SuperCab
ReplacingTurn Switch
1. You are going to need a steering wheel puller.
2. You remove the steering wheel center.
3. you remove the large steering column nut, then install steering wheel puller to remove the steering wheel. It is necessary to mark the shaft to the steering wheel so that it will go back in the same position.
Once the steering wheel is removed, you can see the turn signal switch. There is one center screw that holds the turn signal switch inside the steering wheel hub.
Once the screw is removed the signal can be lifted up over the steering wheel shaft.
Now leaving that, go underneather the dash area and remove the smallpanel around the steering wheel shaft. There you will find a large electrical connector with all the wires that are used in the steering column. This connector can either be fed up thru the column or by disconnecting all of the wires and feeding them up through the column.
this will remove the old switch. The new switch and its wiring harness must now be fed back down the steering column and then reconnected to the large electrical connector.
Now re-install the new switch, screw the turn signal stem back into the switch assembly and the re-install the steering wheel, according to the aligments marks you made, otherwise your steering wheel will be off centered. Tighten down steering wheel center nut, and other panels. Check operation of switch.
Factory manuel gives mechanics 1 hour to do this, but it cam take up to 4 hours.
Bill
Nov 23, 2008 | 1999 Ford F250 Regular Cab
Ignition switch locked up
Try and turn the steering wheel at the same time to take off pressure. If it still wont turn call a locksmith we are usually cheaper than the dealership or if you a mechanically inclined let me know and I will try and tell you how to remove it but it is a lot of work dash will have to come out. Probably what happened is the retainer cover that holds in all the wafers has popped loose very common with gm new ignitions they were better off with the old system hope this helps you
Sep 09, 2008 | 2003 Chevrolet Malibu
Razor 300001-SL Ground Force Go Kart Logo
851 people viewed this question
Top Razor Toys Experts
gbob59
Dennis Key
Dennis Key
Marvin
Marvin
Are you a Razor Toy Expert? Answer questions, earn points and help others
