Lexmark E250dn Laser Printer Logo
Posted on Jan 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The paper light won't stop blinking - there is more than enough paper, new toner, new holder in which toner sits and it won't accept manual feed. What's the problem ?
Anonymous
Level 3:
Genius:
  • Master 1,087 Answers
  • Posted on Jul 11, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1087
Questions
0
Helped
490529
Points
2129
The light sequence means that the output bin is full. Remove printed pages from the output bin.
Press Continue to clear the error code.
For further assistance, please contact Lexmark Technical Support.
Minolta 2400W Wont try to feed paper.
IT is 16year old today, and there are no spare parts, for it.
cept used on ebay.
the blinking lights in the manual mean, toner cartridge dead or fake one installed. on page 11.
if got it to work there are no windows 10 drivers, now. XP yes.
see that page 11 states on errors.
https://www.manualslib.com/manual/90066/Konica-Minolta-Magicolor-2400w.html?page=11#manual
the service manual is here,
https://www.manualslib.com/manual/805991/Konica-Minolta-Magicolor-2400w.html
RTM?
2answers
How to fix the red light and not working on samsung ML-1866?
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see "Clearing
Paper Jams" on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See "Installing the Toner
Cartridge" on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Why has my manual feed stopped working?
I would hazard an educated guess that the pick up roller for the manual bypass slot has become coated with dust and paper fibre. Open the front hatch and remove the toner/drum assembly. Clean the pick up roller just inside the cavity below where the drum "handle" would sit. I recommend alcohol and a cloth wrapped around your finger, and try to rotate the roller to clean as much of it as possible.
Samsung printer ML2010 has online error with a red light how do I fix it?
On Line/Error LED
lights red
receiving data.
1helpful
2answers
Paper light keeps blinking, paper full, won't print
Paper light blinking could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
4helpful
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
2answers
Xerox 3001 Copier. I installed new toner and the
Paper must cover the center to hit the sensor. If paper still goes through without stopping, the paper drive clutch is faulty.
1helpful
2answers
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
receiving data.
Printer ML2010 not responding
On Line/Error LED
lights red
receiving data.
Light blinking
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
