Flash your rokr e6 . and your code is be default ....
for flash help go to this link..http://www.gsmindia.in/forum/p2k-series/11437-flash-your-motorokr-e6-at-home.html
or try this step..
Go
to your Dial Pad and dial: WWW008W. To make the W hit the menu button
while in the dial pad, then hit insert->insert wait to make the W .
You should see something like:
R533_G_11.12.08P
BP: R533_G_11.12.08PB
PFlex: GSZMCAUT678SW016
DSP: 63343400 TECHNOLOGY
Look at the numbers at the end of the first line for the version. The version shown here is .08P.
The Following are all Generic Firmware
R533_G_11.12.02P
R533_G_11.12.06P
R533_G_11.12.08P
Change Log - Nothing has changed until 08p which includes an EQ for Real player & Screen 3.
1. Download the file Motorola_USB_Driver_32_v2.7.6 to your PC and unrar it to your desktop so you can easily find it.
2.
Install a program called "RSDLite" on your PC. To Download RSD lite
Click thread for the file. For trouble free installation, if you are
running Windows XP, you should have Service Pack 2 installed.
3. Download the firmware file that you want to flash to and unrar it to your desktop.
4.
Start up RSDLite on your PC. You may be asked to install a number of
drivers (5 or 6) to your PC. Point it in the direction to the
motpcsdrivers folder you unrared.
5. Put the phone in Bootloader
Mode - MBM mode by turning on phone while also holding down the Camera
Button and the On/off button (These need to be all be held down
together). The phone should start up with a red screen and say its in
MBM mode.
6. Plug phone in using usb cable.
7. RSDLite
should list the phone (this may take a minute or so. If it does not
close down RSDLite and restart it). Start the flash process, by clicking
the button on the top with the ??? and select the firmware file to
install then click ?Start?. The process will take several minutes so be
patient, the screen on you phone will turn off, but RSDLite will still
show progress.
8. When the "Found New Hardware" screen pops up,
select ?NO? for ?Can Windows connect to Windows Update?? then select ?Y?
for ?Install Software from a specific location? and point it to the
motpcsdrivers folder you unrared. Once the driver has installed, click
on ?Finish? on the ?Found New Hardware wizard? to continue the process.
9.
You will need to install quite a few drivers ? so just keep repeating.
It may ask you to manually restart the phone ? if so, unplug the cable
from PC, remove the battery for 5 seconds (make sure unplugged first!),
put battery back in then turn phone back on.
10. Once its fully on, go to Setup --> USB Mode and change mode from "Mass Storage" to "Modem".
11. Plug phone back into the PC using the cable. RSDLite should say "complete" or ?PASS?
12. Unplug the phone again, turn it off and on. All should be complete.
You
can now restore all your contacts, calendar and tasks back to your
phone using MPT. (Be sure to remove the SIM card before doing this as
the recovery function from MPT deletes any contact on SIM for some
reason!)
Try This This Helps
by....ASHISH KUMAR
