SOURCE: Self clean feature on coffee pot
here is the link to the manual http://www.cuisinart.com/share/man/25_man.pdf page 8 - looks like you have a calcium buildup - descale overnight using vinegar/water 50% if the self clean feature is not able to deal with the problem. hope this helps :)
SOURCE: Coffee pot turns stops brewing in the middle of the cycle
i know you said you clean it but did you use a decaler calcium kill those machine pour 1solution 1part water put it on rince very good the decaler is nasty stuff hope it work cheers
SOURCE: Won't brew a full pot.
well I hope this helps some, i was having a similar problem with my brewstation and decided to take it apart ( why not, it's already broken! ) this machine has seen a year of very heavy use and I could not bring myself to just throw it away. It would take forever to brew and I would have to turn it off and on several times to brew a full pot. I unplugged the machine, emptied out the water and turned it on it's back. Remove the 4 phillipshead screws and the two torx screws from the bottom ( if you dont have torx handy like me just gently pry the two halves apart till the screws pull through- after you have removed the phillips heads!) at this point the bottom will just come right off, no special tricks. You will now see a horseshoe shaped aluminum tube with orange silicone tubes at either ends of it, this is the heatime element. slide the small hose clamps back away from the element on the hoses and pull the hoses off both sides of the element end only, this will require a little elbow grease to do. Now carefully remove the two phillips screws securing the heating element to the maker BE OBSERVANT AS TO HOW THE WASHERS AND SPACERS ARE SECURED and remove them. To give yourself a little room for the element to come further out of the machine also remove the wiring clamp from the inside, it is a white half "c" plastic piece with 2 screws holding it, it is securing about 7 wires down with wire nuts on them. Once this is removed it will give you enough play to pull the heating element several inches away from the machine, do so. Now look inside the tubes of the element and you should see one side looks clear and clean and the other end is probably going to be clogged solid with tan colored gunk, the water could not pass through!. I took a piece of metal coat hangar (all i had around at the time) and bent it to the conture of the element and used it to **** out the element, uncloging it. this takes a little time because the buildup is very hard to break up. Once that is done carefully wash out the element getting all the build up that was broken up out, CLEAN IT GOOD!. The next step is to dry the exterior and make sure all the wiring is dry, try not to wet the wires at the wiring nuts or it may short out. Now re assemble the machine, run cleaner through and enjoy a cup of coffee !!
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
SOURCE: Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
