Question about LG GSA-T20N DVD±RW Dual Layer Burner
My computer has given me an error on hl dt st dvdram gsa t20n. Can you please help!
Posted by billkath_pal on
Brian Sullivan
  • LG Master
  • 27,725 Answers
Until you no exactly what has caused the problem you cant fix
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
or you could download a registry cleaner
also
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Jan 29, 2011
My A205-S5855 would not boot. I used RECOVERY disks and got system up and running...BUT now the A205-5855 will not recognize the HL-DT-ST DVDRAM GSA-T20F ATA Device (DVD-CD Drive). I reinstalled drivers...
Sad news when ANY company SELLS SYSTEMS but offers such poor driver support!
TRY this YOUTUBE link:
Solution HL DT ST DVDRAM GSA T20N ATA CD DVD device has disappeared
Also be sure to check the other links offered at that address too... in the TEXT replies.
Hope this helps!
Anthony
Nov 26, 2017 | Toshiba Computers & Internet
Dvd driver noy found
There is a Microsoft KB article on this subject. Here is the link :
http://support.microsoft.com/kb/314060
Just follow the instructions and it may solve your problem
Jun 09, 2009 | Computers & Internet
My HL-DT-ST DVDRAM GSA ATA DEVICE CANNOT SEE IN MY
This error code is generally caused by a corrupted entry in the registry relating to your drive. Please click the link below, scroll down till you see the little repair guy and click on him. This should fix your problem, if it does don't forget to come back and rate this solution, if it doesn't, check to see if the error has changed and add a comment back here so we can look a little closer.
Hope this Helps FixYa,
Chris
May 14, 2009 | Computers & Internet
HL-DT-ST DVDRAM GSA-T20N ATA Device will not read any discs and has a error code 39. HL-DT-ST DVDRAM GSA-T20N ATA Device (code 39) will not work, any help pease? I have the same problem,,my notebook is a...
I read over the solution to the problem by deleting the lower keys in the registry,,restarted and it works fine again,,thank you.
The 1st time I tried it, there was now upper or lower keys because i had uninstalled the driver 1st.
Jan 04, 2009 | Intel Durabook V38263 Notebook
LG GSA-T20N DVD±RW Dual Layer Burner Logo
186 people viewed this question
Top LG Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
