Question about NetGear WG602 802.11g/b Wireless Access Point
Hi, I can connect my iphone to my Netgear WG602v4 access point but it will not open safari or pull any data. my compaq laptop works fine wirelessly but the iphone and my wife's iTouch will not pass data.
Posted by sjones1282 on
5 Related Answers
Anonymous
  • 110 Answers
SOURCE: Netgear WG602 wireless router, Connection Local only !
What I think is you unplgged them at the wrong times.
Do this:
(in this order)
  1. Turn off the router.
  2. Turn off the modem.
  3. take out all the Ethernet cords from the router, EXCEPT the one coming from the modem
  4. Now turn the modem on.
  5. Wait for the lights, then wait about another minute for it to settle.
  6. Turn on the router, make sure the Internet,Lan,Wlan,etc lights are on and functional if it doesn't display a light let me know.
  7. Now depending on what your wireless network (SSID) is called try to connect to it. Go to Start>Network>Click Network And Sharing Center at the top>on the left select Manage Wireless Networks>now click add, if your network is already on the list shown select it and click remove otherwise click "Add" click "add network in reange of this computer" select your network name and click connect.
Now tell me the errors, like if it says connection limited,etc...
Thanks,
Cam
Posted on Oct 19, 2007
Anonymous
  • 611 Answers
SOURCE: Netgear MR314
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at
the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network.
Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other
end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a
standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical
outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result
in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each
other across a network, such as the Internet.
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router.
The next few pages tell you, step by step, how to configure your network settings based on the type of Windows
operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network
adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/IP line for the applicable Ethernet adapter.
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
itself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart
your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area
Connection listed). Double-click the Local Area Connection. Click the Properties button.
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the
OK button again to complete the PC configuration.
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the
Classic interface (where the icons and menus look like previous Windows versions), please follow the
instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon.
Then click the Network Connections icon.
click the Properties button.
button. Click the OK button again to complete the PC configuration.
Posted on Jul 08, 2008
Ausified
  • 69 Answers
SOURCE: Connection to internet through netgear wireless access point
Hmm,,,best I can say then is reset the modem to factory settings and then set it up all over
Posted on Apr 15, 2009
anandg27
Anand Gupta
  • 1272 Answers
SOURCE: Wireless won't connect
Perform the steps below to configure wireless connection settings on the concerned computer:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 17, 2009
Anonymous
  • 2653 Answers
SOURCE: how can I configure a netgear wireless access
What do you mean by talk? Are you trying to bounce the wireless signal for a greater range?
Posted on Nov 21, 2009
Can't open 192.168.0.227
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 25, 2012 | NetGear WG602 802.11g/b Wireless Access...
Can't access 192.168.0.227
This configuration IP address is wrong for the Netgear.
http://192.168.0.1
I have Netgear DG834G v3 working fine on 3 laptops (vista) 2 iPhones ps3 and wii with wep and no issues. I bought a new printer which requires wpa to be used but when I change over nothing will connect....
http://192.168.0.1
The default PW = password You can now change the admin password and configure thewireless settings.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 15, 2011 | NetGear DG834G Router
How do I rename the netgear connection and make it security enabled? I have WG602v2 router
Please follow steps to make your network secure and change network name.
1. Connect the computer to 1ST Accesspoint using a Ethernet cable.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the Accesspoint (usually http://192.168.0.227).
4. Login to the Accesspoint (Username = admin Password = Password unless you have changed it).
5. click on Wireless Settings in the left hand side menu under Setup.
6. Change the network name SSID to (any name) and click apply.
7. Click on Security Settings in the left hand side menu under Setup and select Security Type as WEP.
8. Select Authentication Type as Open System.
9. Select Encryption Strength as 64 bits.
10. Under Security Encryption (WEP) Key in the Key 1 box enter the same 10 digit key that was used on the router before.
11. Click Apply.
Hope this will resolved your issue
Thanks for using Fixya
Jun 12, 2010 | NetGear WG602 54Mbps Wireless G Access...
My Netgear WNDR3300 just quit putting out a wireless signal. I just bought a new Compaq notebook and the wireless internet was working for like three days and now nothing. And it is running windows 7 and...
It seems that router wireless setting need to reconfigure,please follow steps to resolved issue
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. If WPA is selected in Security mode, then check the Password that show up in the passphrase box.
now try to reconnect wireless
May 14, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Apple ipod wont connect to netgear router
If you are unable to connect your Ipod, it means wireless setting on router is incorrect,you need to reconfigure wireless setting on router.Please follow steps to resolve your issue
Connect a computer with a cable to router.
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
5. SSID should be "wireless-netgear"(OR any new name)
6. Under security option select WPA>PSK
under passphress type "9080706050" then click on apply
Now reconnect your Ipod wireless
Hope it can resovle your issue
Mar 27, 2010 | Apple iPhone Smartphone
My itouch says its connected but wont open any webpages
Please follow the steps below to login to the router page and check the network key:
make sure that other wireless device is working fine,if it is working fine then you can try these steps
5. Changed SSID(network name)and changed security
6. click on wireless setting'(under advanced)
7. click on SETUP ACCESS LIST (Turn Access Control On)it should be unchecked
then try to connect wirelessly
regards
prakash
Mar 11, 2010 | NetGear DG834G Router
I have a iphone 3gs and want to access wifi or wireless on toshiba satellite pro x200
Laptop normally have single chip WiFi or Wireless Cards...
These cards could be used as client(connecting to wireless router), adhoc or access point(a WiFi card could be used as Access Point to route your LAN(Wired) connection on WLAN)...
Your laptop WiFi card is already busy as a Cleint, so if you want to use it as AdHoc, you have to remove all the other connection with the WIreless...ie, Disconnect the WLAN from connecting other devices, and follow the below mentioed steps to connect your device..
When you are using Client mode you are not able to use it on Ad-hoc or Access Point feature...
Setup laptop to Ad-Hoc
1)Navigate to control panel and choose network connection, Right click on the Wireless network connection and click on the Properties on Wireless NIC
2) Click-Wireless Networks Tab
3) Click-Add
4) Provide SSID Name, name to identify you rnetwork
5)Security -Net Auth: Open
6)Make -Data Encryption: Disabled
7) In the check box present-Check on This is a Computer to Computer (ad-hoc) network.
Change the IP address of the Wireless NIC card, by choosing TCp IP in the properties of WLAN and choosing TCP/IP v4 from the installed service
TCP/IP on Laptop
-IP: 10.0.0.1
-Subnet: 255.255.255.0
TCP/IP on iPhone
-Static IP
-IP: 10.0.0.2
Now try searching for Wireless through your phone, you should able to connect..
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Nov 01, 2009 | Computers & Internet
NetGear WG602 802.11g/b Wireless Access Point Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
efs_perpends
efs_perpends
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
