Starting the Installation
Log on to the PC as Local Administrator.
Windows 2000: Double-click on the
My Computer icon on the desktop. Double-click to open the
Control Panel window and then double-click on the icon labelled
Printers. Double-click on
Add Printer to start the
Add Printer Wizard. The dialog below will be displayed.
Windows XP: From the
Start menu, select the option
Printers and Faxes. Click on the task
Add a Printer to start the
Click on the
Next button to display the dialog shown below. Ignore the instructions in this particular dialog box because they are incorrect.
The Wizard provides installation options for local and network printers. Select the option
Local printer if you are installing drivers for a personal printer (using a USB, serial or parallel connection). If the option
Automatically detect my printer is selected, you will see the warning message below.
If you are installing drivers for a TCP/IP LAN printer, you should also select the option
Local printer. For a LAN printer, always ensure that the
Automatically detect my printer option is not selected.
The
Add Printer Wizard will display the dialog below so that you can specify which port (connector) the printer uses.
For a personal printer, ensure that the button for
Use the following port is selected. From the list, select the Local Port to be used -- this is normally the parallel port, LPT1. If you are unsure, please refer to the documentation supplied with your printer or check which type of cable is being used.
thanking u for using fixya
