Changing the all-in-one control-panel display language
Use this procedure to print reports or to show messages on the all-in-one control-panel display in a
language other than the default for your country/region.
To change the all-in-one control-panel display language
1. Press Menu.
2. Use the button to select System setup, and then press (tick sign)
3. Use the button to select Language, and then press (tick sign)
4. Use the button to select the language that you want (tick sign)
5. Press (tick sign) to save your selection.
The all-in-one automatically restarts
1. Turn off the all-in-one.
2. Press and hold down the * and buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. Allow the all-in-one to return to Ready before using it.
After following these instructions, when you restart, unit should prompt you to select a language. Use the left right arrow keys to select proper langauge and press checkmark to accept.
Once it resets it will prompt you to set the language, use the arrow keys to select English and then press the checkmark. Unit will restart in English mode.
