Question about Kenwood Food Processors
I have solved it at last! Remove the 5 screws on the bottom. There are 2 more screws (which may be blackened with oil) located through the grille directly below the motor. They're stumpy little things with gripping washers. I had to bend the plastic grille thingys to get screwdriver in. Once released, these will enable the whole base to be removed. Then there are 3 screws to get the plate off to put the new belt on. Put the belt around the big cog. Replace the 3 screws of the plate. The motor drive is loose now so you can angle the drive cog to attach the belt to this. Using gravity by turning the processor on it's edge you should with some fiddling be able to put the stumpy screws back in - took me a couple of goes. Replace the 5 screws and robert is a very close relative.
Posted on Jan 29, 2011
THANKS FOR THE TIP, HOWEVER, REPLACING THOSE TWO CHUBBY SCREWS WAS A CHALLENGE!
You can remove the top section if you take off the blender drive cap and unscrew the blender drive cog CLOCKWISE. Then remove the 5 screws to free up the base and motor assy.
To hold the chubby screws in place, use elastic small elastic bands around the screw then around the suction feet
Hi Dave..Can you please help..I have kenwood food processor and I managed to put the driver belt in [which was broken]. but now, not able to put the assembly back. The main problem are the 2 small screws which needs to go below the bottom base. How can I put them ....spent 2 hours already ..no luch :(
Jan 30, 2013 | Kenwood Food Processors
Aug 02, 2012 | Kenwood KM336 Chef Food Processor
Mar 24, 2011 | Kenwood Food Processors
Feb 04, 2011 | Kenwood FP110 338 Cups Food Processor
Dec 13, 2010 | Waring FPC15 10 Cups Food Processor
Jun 07, 2010 | Kenwood Food Processors
Feb 07, 2010 | Kenwood Food Processors
Sep 29, 2009 | Food Processors
584 people viewed this question
