Question about HP Photosmart C7280 Laser Printer
0XC05D1281 - HP Photosmart C7280 Laser Printer
Posted by pdriscoll on
Jessica Michael
    Master:
  • HP Master
  • 459 Answers
Please make sure that the printer is connected directly to the wall outlet and not to the surge protector.
Step 1: Remove all the ink cartridges and then try to perform a hard reset on the printer.
Step 2: With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
Step 3: Remove USB cable, if present.
Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
Step 4: Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord and then plug back the power cord to the printer.
Step 5: Turn on the printer and wait till warm-up period finishes and the printer is idle.
Step 6: Now insert the ink cartridges and then try to print a test page and check if it works.
Step 7: I will be sending you the steps for the Semi-full reset as a private message, which restores the printer to original factory default settings.
Please try these steps still have issues Call Our Toll-Free 1-888-224-4280
Posted on Sep 07, 2018
ipan_esdm
    New Friend:
0XC05D1281 Problem with the HP Photosmart C7280 Laser Printer 0XC05D1281 Help me
Posted on Mar 07, 2011
HP c8180 error code oxc05d1281
http://h30434.www3.hp.com/t5/Other-Printing-Questions/0xc05d1281-Error-code-for-Photosmart-C8180/td-p/1212853
Apr 10, 2015 | HP Office Equipment & Supplies
HPPhotosmart 3210 AIO hangs us with error code of 0xc05d1281
Hi Minnie,
This could be because of residue on the Printhead electrical contacts
Try the steps below and it should help.
Turn off the Printer.
1. Open the Carriage access door.
2. Remove the Cartridges
4. Move the carriage from left to right 6 times and it should move freely
5. Clean the contacts on the Cartridge with lint free cloth. ( Golden dots )
6. Turn on the printer and it should say " Cartridge missing or need to be reinstalled "
7. Install the Cartridges and close the Carriage door
8. the printer should go through alignment process
If this step does not fix, You may try calling HP customer support to check for better options/solutions
HP Customer Care : 1-800-474-6836
Regards,
Sean
Feb 16, 2013 | HP Photosmart 3210 All-In-One InkJet...
Error code 0xc05d1281
Try the steps in the following website:HP Website
It may help.
0xc05d1281
A full guide for clearing all 0X error codes can be found here. I would normally paste the solution but there is so much information you may be best checking out the whole thing (with images).
Hope this helps.
Nov 01, 2012 | HP PhotoSmart Office Equipment & Supplies
0xc05d1281
Without turning off the product, disconnect the USB cable from the rear of the product.
Remove the cartridges from the product.
Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
Disconnect the power cord from the back of the product.
Wait 60 seconds.
Reconnect the power cord. If the product does not automatically turn on, press the Power button
Reinsert the cartridges, and then close any open doors on the product
If you receive a prompt to print a calibration page, do so.
If you disconnected the USB cable, reconnect it to the rear of the product.
Try printing again.
Try with a different set of ink cartridges...
Try doing a reset : Unplug the power cord from the product, and wait 20 seconds.
Press and hold # and 6 while plugging in the power cord to the product.
Release the buttons after the product starts up. The product will now be reset to factory defaults.
Hope this helps for you
Oct 31, 2012 | HEWLETT-PACKARD Photosmart C7280...
Error 0xc05d1281 HP Photosmart D7160 InkJet Printer
The best solution is don't buy another HP printer, get away from the inkjet printers all together they'll nickel and dime you to death! Go with a laser printer, why do you think over 75% of business use them instead of inkjet printers?
Jan 31, 2012 | Office Equipment & Supplies
Display says error 0xc05d1281
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 03, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink System Failure with error code: 0xc05d1281
I had the same problem and took Guru NinaE advice....1. Unplug power cord from back of printer while it is on. 2. Wait for 60 seconds after it is in sleep mode. 3. Press and hold "Print Photos" and "Red Eye Removal" at the same time and while holding the two buttons down, plug in the power cord into the back of the printer. 4. The printer display should go blank or Reset might show up on the display. When this happens, touch the ON button and the printer will reset itself.
May 20, 2009 | HP Photosmart C8180 InkJet Printer
HP Photosmart C7280 Laser Printer Logo
347 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
