Question about Brother MFC-260C All-In-One InkJet Printer
Trouble shoting and routine maitenance chapter in users guide 34 unable to print
Posted by hossaion on
RAJDEEP DUTTA
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Jan 29, 2011
Dcp-165c clean unable trouble shooting and routine maintenance chapter in user's guide 46
for non fax models ie I have DCP 165C you say press ...... press up arrow four times then press 8 then 0 etc ... but I have no numbers to press!
Jul 15, 2012 | Brother DCP 165C Compact Color Inkjet...
THE LCD SCREEN SAYS PRINT UNABLE 50 AND SEE TROUBLESHOOTING AND ROUTINE MAINTENANCE CHAPTER IN USERS GUIDE.
Read the users guide and do what they say in the Troubleshooting and Routine Maintence Chapter for the "Print Unable 50" error message.
Mar 29, 2011 | Office Equipment & Supplies
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . [email protected]
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Will not print
www.brother.com has those user guides by model number..
Jul 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Will not print
What 2 digit error code does the machine display, too?
May 12, 2008 | Brother DCP 130C All-In-One InkJet Printer
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-260C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
