Question about Acer TravelMate C302XMi Tablet PC
Need all drivers as have removed old hard drive & installed new drive
Posted by mojive247 on
Chris Hingee
  • Acer Master
  • 32,281 Answers
Download the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Posted on Jan 29, 2011
Sylvania-9-inch-portable-dvd-player- how to bypass login
That is a problem when the computer has been setup for another individual. The only way to get around this problem is a complete replacement of the operating system from scratch.
If you purchased the computer from a reliable store, I would go there and have them reinstall Windows.
If that is not an option; you must purchase a new copy of Windows 10 (2017-18 Version) usually the Pro version. Make certain you get the Latest Windows and NOT an Old version that needs updates.
Personally, I reformat my hard drives to eliminate pervious data lingering on the hard drive. But you can run the new Install over the old if you need to do so. Once you have the NEW Windows installed, you will be directed to answer questions relating to you and that data is associated with your computer, as was the situation when you got this computer from the store.
My acer 4315 got problem with sound device. I have no idea how how to fix it.
WE NEED TO REMOVE AND REINSTALL YOUR DEVICE DRIVER _Driver_1.00.01.zip file and save to your desktop. Use a file compression software to unzip the file located inside MyBook_vista_windows7_Driver_1.00.01.zip to your desktop. You will now see a file called "MyBook_vista_windows7_Driver_1.00.01.exe" or "MyBook_vista_windows7_Driver_1.00.01" on your desktop. Double-click on "MyBook_vista_windows7_Driver_1.00.01.exe" or "MyBook_vista_windows7_Driver_1.00.01" to launch the driver installation program. The wizard will display a message saying that it is ready to install the driver, click Next. Accept the license Agreement and click Next Click Install to start the installation of the drivers. The driver will be installed without further interaction and should take only a few seconds to install. When the installation is finished, click Finish to close the installation utility. Reboot the computer system before connecting the My Book Essential or Premium Edition hard drive. After connecting the My Book Essential or Premium Edition hard drive, Windows will automatically detect the unit and a new hard drive icon will appear in the My Computer window. Your My Book Essential or Premium Edition hard drive should now be ready to use.
Bought used toughbook on ebay, no hard drive or OS. using my old hard drive from broken one. get to bios screen, but will not boot up into windows. I'm guessing some drivers may be jacking me up, how do I...
reformat the had drive and install a fresh copy of OS from the compact disc.... once the installation is complete, boot up the computer again... if it works, then every thing is perfect....you can go ahead and install the drivers for your devices in the compter...
please clarify if you have any further troubles in installing the OS in your computer...
2answers
I changed the hard drive in my m400 and i doesnt load windows says somthing about a dianostic disc! what do I do.
You haven't said whether you installed Windows from the original factory discs which came with the laptop. If you haven't done that yet, open the cd tray and put the 1st disc in. Shut down the laptop. Reboot the laptop and it should boot off the disc and ask you if you want to "format" the hard drive. At this point you should be able to follow the on screen instructions until everything is loaded, including all hardware drivers. Any other software you had on your old drive will need to be reinstalled on this drive from the disc. If the software is old you may want to go to the appropriate website for the driver and download the newest version. That should complete your install. Let me know if you need more help.
hardrocko
Thanks for using FixYa and the generous rating.
I want to format my drive but it say's os loader cant load
you have to use a boot up disk or boot up to safe mode with command prompt and have a boot disk to format a drive that is XP or Me or Server2000 or 2004 or simply use your system install disk to format the drive before reinstalling system, you can do a destructive install which will allow you to format it that way. However I prefer to have a boot disk and boot to a windows 95 or 98se disk and boot to a floppy or a CD. Problem with this is if you have old drivers you will lose all driver information if you don't back up drivers. if you have old components it will be a pain in your backside to load all the new drivers.
The up side is you destroy all disk information including any identifying information on the disk you start with a Cleon disk and can add a disk partition to install your O.S. on and your drivers. This is not to hard to do but for a first time person you have to know the sequence to do it in. If you want to know how to do this let me know and I will give you the instructions in the exact order to do it the latter way. Thanks for using Fix-ya and hope this helps.
Hard drive replacement
Hard drives are easy to replace, they are located in a separate compartment. Depending upon the model of your laptop, it could be located on the bottom or on the front or left or right hand side of the laptop. The hard drive may have an adapter connector that fits over the 44 data pins on the hard drive.
For further information please click on this link :-
http://www.fonerbooks.com/laptop_1.htm
After you install a new hard drive, you need to format the hard drive and install Windows on the hard drive plus the device drivers of the devices that are installed on the laptop eg. video, audio, modem, LAN and wireless etc.
2answers
Install new hard drive m280e
~er~ what do you wanna to say ? how to install new hard drive?
if yes,you can reference the article :Illustrated how to replace a laptop hard drive
hope it can help you
2answers
Unable to install OS on Hard drive. Error PXE-E61: Media test failure, check cable. PXE-MOF: Exiting PXE ROM. Invalid partition table
When your computer failed to boot from the disk-drive, it tried to connect to a network-accessible "boot-server" via the Ethernet adapter.
However, if there's no cable connected to the computer's Ethernet port, you will get the "check the cable" error-message.
So, your real problem is "invalid partition table", which means that the very first record on the disk-drive is either missing or corrupt.
That first record contains the "partition table", which lists the size of the hard-drive, and the size of each partition (usually only one) on the hard-drive.
So, you'll need to buy an adapter that has a USB-plug on one end, and a connector for your "SATA" or "IDE" hard-drive at the other end.
Remove the hard-drive from your computer, attach it to the connector, and plug-in the USB connector to a USB port on another computer, and then use software to delete and then reconstruct the partition table.
Or, the hard-drive is failing, and must be replaced (maybe under warranty???).
Itronix Gobook IX250
before upgrading xp plz visit the manufacture website and check for drivers for xp.
xp needs min of 256mb of ram
Can't install xp - freezes
You need a CD/DVD USB drive.
Ask for one or use a HD 3,5" USB drive, open de HD USB disconect the HD and conect a CD drive, it will work like a CD USB drive.
Acer TravelMate C302XMi Tablet PC Logo
Top Acer Tablets & eReaders Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
NOEL
NOEL
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
