Question about Nokia 5200 Cellular Phone
Hanging allkeys - Nokia 5200 Cellular Phone
    President:
  • 1,812 Answers
If you restore the mobile can solve your hangink problem.
Before restore the mobile please take a full backup.
First Try it:
You may try default phone and security code to remove it
Default phones codes is 12345 or 00000 you can use it
Go setting>factorry setting >reset ....
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
If
Soft reset( factory setting)
On Sybmian phones:just type it it will start automatically,
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
If the problem same please Hard reset your mobile .
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you don't understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate and leave a short comment,that is your choice.
Hope this helps.
Posted on Jan 29, 2011
6ya staff
SOURCE:
Lyrics to 1958 song Tom Dooley by Kingston Trio
[Intro:]
Throughout history
There've been many songs written about the eternal triangle
This next one tells the story of a Mr Grayson, a beautiful woman
And a condemned man named Tom Dooley...
When the sun rises tomorrow, Tom Dooley... must hang...
Hang down your head, Tom Dooley
Hang down your head and cry
Poor boy, you're bound to die
I met her on the mountain
There I took her life
Met her on the mountain
Stabbed her with my knife
This time tomorrow
Reckon where I'll be
Hadn't a-been for Grayson
I'd a-been in Tennessee
This time tomorrow
Down in some lonesome valley
Hangin' from a white oak tree
Poor boy, you're bound to diePoor boy, you're bound to die
Poor boy you're bound to die
Poor boy, you're bound to die...
Feb 19, 2015 | best-song-lyrics.com
Utorrent is not responding.
have you tried to reinstall utorrent? if so, and it still doesn't work, you can remove utorrent and then run ccleaner which you can download from piriform.com after running it, try and do the installation again. if still no help i'd try a different torrent program such as vuze.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 09, 2012 | Computers & Internet
A problem caused this program to stop interacting with Windows. Problem signature: Problem Event Name: AppHangB1 Application Name: plugin-container.exe Application Version: 7.0.1.4288 Application...
Seems more likely that there was a virus threat and attack that had caused the firefox browser to hang up. You can shut down and restart, try and use a good active antivirus to scan, check and repair if there was any damage on the OS .If not you can uninstall the forefox and reinstall.
Nov 08, 2011 | Mozilla Firefox
2600 restore key and allkeys
hi there!
Let me give you the steps on how to restore the factory setting
of your phone.
Before you start, ill be advising you to please backup all the
information that is stored on your phone because a hard reset
will delete all the files from your cellphone.Remove the memory
card, if necessary, and write down any phone numbers or
contacts that you want to save.
After that, please dial *#7380# on your phone.After that
please select "Yes" at the subsequent prompt to indicate that
you approve of the operation. Enter the master code, if required
by your model. If you haven't set the master code, use the
default code "12345." Wait for the phone to conduct the reset.
It may turn off during this process. When completely finished,
the phone will return to its normal non-call screen.After doing
this, kindly insert your memory card if the phone.
Thanks!
Apr 20, 2011 | Nokia 2626 Mobile Phone
Problem Event Name: AppHangB1 Application Name: YahooMessenger.exe Application Version: 9.0.0.2152 Application Timestamp: 49c1a403 Hang Signature: 441b Hang Type: 1 OS...
Just uninstall it through control panel then install the latest version and you shouldn't have a problem. Cheers from Scott and plz vote
Jan 13, 2011 | Computers & Internet
Hi there, I am using a compaq 615 with Vista and am having trouble using the web cam. So I downloaded the software from :...
I think you will be better advised to uninstall the current software and download the latest webcam software from the HP support website
Dec 14, 2009 | HP Computers & Internet
Arcsoft VideoImpression
This is windows Vista? What have you changed since it started crashing? The most common cause of crashing programs like this are the result of a graphics driver.
Mar 07, 2017 | Arcsoft VideoImpression 2 for PC
IBM Correcting selctric II keys are jammed
It sounds like the cycle shaft is not fully in home
position. With the machine OFF, try to turn the print shaft (the steel shaft with the single groove that goes through the carriage) top towards the back of the machine. Then turn the machine on. Try the space bar first. If it works, your machine probably needs the cycle clutch spring adjusted or replaced.
Feb 18, 2009 | IBM 3500 Typewriter
CanoScan Toolbox will not remove
http://www.revouninstaller.com/revo_uninstaller_free_download.html
download this soft
then uninstall your soft whihcu want to uninstall select it.
then also delete the allkeys which show u.
Nov 13, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Nokia 5200 Cellular Phone Logo
48 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
