Question about Refrigerators
KITCHEN AID REFRIGERATOR PROBLEM We bought a used Kitchen Aid fridge YKSRS22Q (1993), the ice maker is not working but water does work. What should we check to see why the ice maker doesn't work?
Posted by gallantw679 on
Aaron Beth
    New Friend:
  • 110 Answers
Ice makers work off of temperature. If it's not cold enough in the freezer it won't work. Check the temperature with a thermometer, it should be 0 to +10F
Posted on Jan 29, 2011
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
Water, but "no ice" in my Kitchen Aid
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 28, 2011 | KitchenAid KSCS25FKSS Side by Side...
ICE AND WATER DISPENSER WILL NOT WORK ON KITCHEN AID MODEL # KSCS25FKSS01
if neither one works that usually is the water valve located on the back of the fridge. Try this manually fill the ice make with a glase of water and check the temp. in the freezer. you can reach in and touch to see if water is freezing in ice maker. see if it dumps the ice then surly the valve is bad
Apr 21, 2010 | KitchenAid KSCS25FKSS Side by Side...
Have kitchen aide fridge ice maker stoped working, replaced ice maker still not working, red light blinks twice? Help
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hkhjkd
Jan 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
No ice from fridge
the water valve has two parts ( ice side and foutain side ) ice side could be bad . the tube in freezer that feeds the water could be frozen . and the ice mker itself may be bad . mm
Nov 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
251 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
