2005 Honda CR-V Logo
Posted on Jul 19, 2008
Six changer cd player
Just bought car second hand, every time i press the "load" button, the word
"busy" flashes for disc 1, it wont let me do anything else. There is no disc in it.
A
Anonymous
IT IS NATURAL IT MEANS THAT WAIT BEFORE YOU LOAD A CD.
My cd player on my Honda passport wont play, it says error 1, what does that mean?
Error 1"The changer is unable to load or unload a disc, the changer can't operate".
Means your machine is in need of repair (unable to load or unload a disc), remove the cd player and send it to the manufacturer for repair (that's what the car dealer will do if you ask them to repair it for you).
My Honda accord Sedan car CD Player cannot eject CD .
Before connecting any cables you must set the dip switch box to the position listed for your vehicle. If you set the dip-switches after you have connected cables to the box, you must disconnect and reconnect them for the changer to operate. All 1992-2004 Honda's are compatible with the Neo Changer except the 2003 and 2004 Honda Accord and all Honda Element vehicles. Some radio models require pressing "Seek >" once to start playing after changing CD or after startup. The radios display will not show the proper disc number after disc six. You can use all 10 discs in the magazine, but the readout will be wrong. This is not a technical problem; the car stereo was designed for no more than six discs. *Due to the direct access disc system, you will not be able to directly access discs 7-10. To access these discs you will have to go to the last track on disc 6 and let it play until it loads disc #7. ( you can fast forward the track, but you must let it play the last 5 seconds of the track, for it to change to disc # 7 Switch to the Neo Changer by pressing the "CD" button. To change discs press "Disc -" and "Disc +" To change tracks simply press "Seek <" or "Seek >" S E T T I N G S F O R H O N D A 1 2 3 4 5 6 7 8 ON OFF OFF ON OFF OFF ON OFF
1helpful
2answers
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
44helpful
2answers
My 2002 ml 320 press cd button it says no cd player installed
my 2001 ml 320 when i press cd button it says no cd player installed massage. There is 6 cd changer in the back of the car ., Any suggestion for fix the cd player?
Please help.
I have a 2007 cadillac cd changer
press the load button in and select what number slot to have your cd placed into. the player will lite up showing a message to load it
16helpful
4answers
Cd player on 2001 lincoln ls - cd error when i press load button
My father inlaw just purchased a 2001 lincoln, with a six disc changer, Question is he loaded the unit ,and now he wants to eject the cd's and the changer won't open? any suggestions thanks
I entered radio reset code for 2002 civic now the clock flashes and will not allow me to adjust it. How to solve this problem
Okay, I'm assuming that you were sucessful in resetting your radio code.
I'm also assuming that you have a CD player (which may not be the case).
The flashing clock also functions as an error code indicator. It should say something, indicating what the error is. You can't set the clock until the error is resolved (a disc stuck in the CD player, for example, on no disc in the CD when it's been told to play).
The procedure is as follows (which you probably know):
The audio system display usually shows the time when the ignition switch is in ACCESSORY (I) or ON (II). It shows the operation mode of the radio, cassette player, or optional CD player/changer when you operate them, then goes back to the time display after five seconds.
If an error occurs while operating the optional CD player or changer, the display will keep showing the error code and will not switch to the time display until the error is corrected. You can set the time only when the clock is displayed.
To set the hours, press the H (Preset 4) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the H button until the hour advances to the desired time.
To set the minutes, press the M (Preset 5) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the M button until the minutes numbers advance to the desired time.
If you don't have a CD player, or no error is showing in the clock read-out, leave a comment so I can investigate further.
Hope this helps you.
1helpful
2answers
CD STUCK IN CD PLAYER
The case needs unscrewing to reveal more of the internals. Go carefully and peer inside wherever you can to fiddle the CD back into place or out of the box. It's in there somewhere, removing panels will get there.
1helpful
2answers
2004 honda accord CD player not working
I have the same problem I bought one with the same problem. Does any one have a solution.
Help
1helpful
CD Error on Stereo (Not a code issue)
I have seen this a bunch of times always with the same result, take it to a audio repair facility, the sterio has a bad internal circut. No external "quick fix" that i know of
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
