Question about Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray
I think our Signature faucet is leaking through the metal pull out coil. It is intermitten. Can a replacement coil be purchased. I'm not sure if this is the real problem though. It is leaking under the sink.
Posted by jnzemil on
Anonymous
    New Friend:
  • 111 Answers
These are really well designed.take a flashlight and go under and look up.most leaks come from stop valves.if the hose is leaking,you can change o rings.oooooor you might have a bad hose.delta will be happy to replace it. I've found there customer service easy to deal with.
Posted on Jan 29, 2011
Delta 470 trying to remove metal pull out spray wand but it gets stuck when trying to remove and replace
Are you trying to just replace the sprayer? I replaced the whole unit so cannot help with just the sprayer.
Jun 08, 2014 | Delta Faucet Delta 470-BL-DST Signature...
Leaking kitchen facet by delta
Great design! Even I think that it's a must have kitchen appliance specially for modular kitchen users.
Aug 24, 2013 | Delta Model 470: Signature Kitchen...
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
My delta signature faucet is leaking from the top of the hose. I want to take the hose out to get a replacement. I have started to disassemble the faucet but don't know how to remove the cap.
i am not sure which cap you refer to. there is a cap just below the handle. turn off the water supply for safety and remove handle then turn the cap counter clockwise. to replace the hose you should only have to disconnect at the handle to the sprayer and the other end at the faucet below the sink. if you wish to remove the faucet then after shutting off the water undo the nut below holding the faucet in place. delta have a good web site where you can see a breakdown of this faucet.
Dec 29, 2010 | Delta Model 470: Signature Kitchen...
Facet still leaking after replacing the RP4993G part.
Make sure the area below where you replaced that part is free of scale and is not damaged in any way. Scuffs, scale and dirt will caused your leaking.
Sep 13, 2010 | Delta Faucet Delta 470-BL-DST Signature...
How to fix leak for delta faucet 470 WHRS
To fix the leak in delta faucet is have a repair kit for
Delta 470-WHRS. The repair kit consist of O-rings
replacement. Otherwise, you have to buy a replacement
for your Delta 470-WHRS.
Nov 26, 2009 | Delta 470-WHRS Signature Single Handle...
Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Mar 24, 2009 | Delta Model 470: Signature Kitchen...
Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray Logo
323 people viewed this question
Top Delta Faucet Plumbing Experts
Muntejaya Ginting
Muntejaya Ginting
Bill Johnson
Marvin
Marvin
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
