A worn nozzle creates a
spray pattern, where a good nozzle creates a
fog.With a coarse spray pattern poor combustion results in an
off colorflame, . The photocelldoesn't like the color, sends a signal to the computer whichshuts everything down. That's the job of the electronics. On HSI ( hot surfaceignitor) heaters it is all about
correct flame color , not just flame.
The part where you write "If I remove the cover again it runsfine" is a symptom of a bad, worn, or restricted nozzle (generally).Remember- the ignitor only stays red for 5 seconds, then the flame keeps itselflit. The nozzle's pattern is a cone. Lift the lid & the pattern widens(aerodynamics) - replace the lid and the cone narrows & possibly distortsthen the flame goes out.
This nozzle rule will
only apply if everything is correct as far asfuel delivery applies. The pump pressure must be correct- not almost correct.Set the pressure with a low-pressure gauge that registers12-15 psi max. A gaugewith a higher scale just will not read close enough to satisfy the system.
If the pressure is not correct, the aboverule will not apply. Instructionsfor setting the pressure can be viewed at
http://reddyparts.com/pressure.htm.
In addition, a fan can cause the same problem if damaged ormis-matched to your specific model.
I must mention that any air leaks onthe pressure side (or vacuum leaks on the fuel line, for that matter) betweenthe pump and the nozzle will create a rich/lean mixture at the combustionchamber, creating an off-color flame.
