Question about Samsung R530 (NPR530JA02US) PC Notebook
Having dropped my Samsung R530 (nothing obviously broken), when I try to stsrt it it is coming up with the message:- "Boot From AHCI CD ROM: Operating System not found" Any ideas?
Posted by tony_prother on
Rofel Lantican
  • 2,632 Answers
Hi tony prother,
"Boot From AHCI CD ROM: Operating System not found" error is because the system is booting the CDROM of the system and its not detecting an installed Operating System. You need to check if the system still detects the Hard Drive of your laptop on the Bios page. To go to BIOS reboot the computer and tap F2 on the system and on the bios page check if the hard drive is detected then go to then BOOT Tab select the hard drive as the first boot priority and reboot the system.
If the hard drive is not detected it might be damage, you can get intouch to a local tech to check and backup the files.
Thanks for using Fixya.
Posted on Jan 28, 2011
5 Related Answers
sayedmohu
Mohammed Ebrahim M
  • 645 Answers
SOURCE: my laptop has gone funny
The boot priority is been changed to CD ROM.
Change it back to Hard drive.
If that doesnt resolve, replace the HDD.
Posted on Dec 03, 2010
TimeDefensiv
Shahzad Waseem Akbar
  • 746 Answers
SOURCE: When I swich ny samsung R519/SA20/E251 when I
There is two possiblities, first is boot sequence problem from your bios setup and second is your boot.sys file has been corrupted and in this can if you professional use console and recover it otherwise reinstall your operating system.
Good Luck
Posted on Jul 10, 2010
djwordz
  • 76 Answers
SOURCE: My Samsung NP R530 turns
after starting up your computer, goto BIOS ( press F2, F12, or DELETE button, depends on the bios ) goto boot settings and switch the first one to your Hard Drive. save settings and exit.
Posted on Apr 06, 2011
Azrael SRL
  • 11800 Answers
SOURCE: my samsung R519 laptop is
Windows has been completely corrupted, the only thing left to do is to reinstall it.
For that press F9 while the Samsung logo is on the screen and then select the Restore option.
Posted on Aug 10, 2011
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: my laptop says boot from ahci cd-rom operating
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
if you need more help with this or if I have misunderstood the problem post a reply
hope this helps you
Posted on Sep 28, 2011
M y laptop wont start it says boot form ahci cd-rom OS not found
hi. change boot priority. if it not work, try this:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&cad=rja&uact=8&ved=0ahUKEwiK29_X6ZfYAhVNZFAKHdAfAccQtwIIUTAF&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DOSYM5dxzHwI&usg=AOvVaw1fFelmab2q_HBoIyDi6LbY
Dec 20, 2017 | Samsung Computers & Internet
Boot from AHCI CD -ROM
You have to enter the BIOS and set the Boot order making the Optical drive first and the Hard Drive second.
Jan 11, 2014 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
Disk read error on Samsung NP-R519 laptop
Check CD-ROM; whether it has scratched CD than difficult to read by CD drive.
Dec 10, 2013 | Video Game Consoles & Games
Samsung r530 bad sector hard drive. Did not come with operating software disc.
Remove the HDD and test, replace if necessary. You can contact Samsung, with your laptop Serial Number, and purchase a Factory Recovery DVD. Or, you can buy a Windows Installation DVD and do a Fresh install on the new HDD.
Jan 06, 2013 | Samsung R530 Notebook
Samsung r530 wont boot up
Unfortunately, in my past experience this particular model it seems to have a very bad habit of hard drive failure on a regular basis. The particular samsung hard drives used in it are horrible and so is samsung support. You don't say weather or not you can boot from the CD/DVD drive with a live cd in it, but you should try getting one and trying it out.
Get a copy of Hiren's boot cd from here:
http://www.hirensbootcd.org/files/Hirens.BootCD.15.1.zip
Extract the iso and burn it to a CD, then put the CD in your CD/DVD drive and boot from it. Use some of the Hard Drive 'diagnostics on the CD to determine if the Hard Drive is Dead Like I think it probably is. Then Contact Samsung support from this page:
http://www.samsung.com/us/support/owners/product/NP-R530-JA02US
Keep after them until they address the problem to your satisfaction. This is a VERY common problem with this particular model so give them an earful!
Jul 28, 2012 | Samsung R530 (NPR530JA02US) PC Notebook
Tapping F8 to get to safe mood doesn't work, what next?
sounds like your MBR is messed up....if you have system mechanic, you can use it as an emergency boot up and fix MBR disc....otherwise, you'll have to use either an OEM builders disk or the requested disc [ACHI cd-rom ] to reboot from.another option would be to try this;http://download.cnet.com/MbrFix/3000-2094_4-10485990.html?tag=mncol;1
get someone to download it for you, or go to the library with a flash drive to record it to, then burn it to a disc, then place it in the computer and reboot, it should reboot from the cd drive first....however it is best to check first...so reboot now, and tap the f1 or f2 key to reach the bios screen...arrow over to the boot option, and follow prompts to make sure the boot order is cd rom 1st, then f10 [ save and exit ] then reboot, then add the MBR fix disc you made AFTER , then reboot again...let me know what happens
Apr 22, 2012 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
Dropped laptop today, switched it on and it starts up, but comes up with black screen with following message: Boot from AHCI CD Rom: operating system not found But before that screen comes up...
It sounds like you might have damaged your HDD when you dropped it. It's saying that the operating system isn't found, and it's trying to boot from your CD ROM. Either that or you might have left a disk in the CD drive, I'm guessing that is unlikely but worth checking maybe. By pressing F2 at start up and going into your BIOS (the Phoenix SecureCore Setup you talked about) Without changing any settings look through it until you find the HDD, or the BOOT options, if it lists a HDD don't get excited as it should be there even if it was damaged and is now unusable. Did you have your laptop on Hibernate, they say to shut them down if your transporting. Since when they are off they park the HDD, but when they are in Hibernate the HDD really isn't off it's on stand by. Making it easy to damage since the HDD is ready to read or write at the click of a button.
Aug 04, 2011 | Computers & Internet
My Samsung R530 won't boot, just shows blue screen of death on startup, states "A problem has been detected and Windows has shut down to prevent damage blah blah blah Unmountable_boot...
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jul 12, 2011 | Samsung R530 Notebook
My Samsung NP R530 turns on but won't boot to windows. All it says is: BOOT FROM AHCI CD-ROM: It never leaves that screen, I know I have a virus but it just won't load at all now. How do I...
Apr 06, 2011 | Samsung Computers & Internet
Samsung R530 (NPR530JA02US) PC Notebook Logo
1,746 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
