Question about Motorola Mobility Bluetooth Headset-Silver/Black Headset
I have a new cell phone and a motorola blue tooth that I need to pair with the new phone. How do I put the bluetooth in pairing mode? I no longer have the orginal owners manual for the bluetooth. Thanks.
Posted by davidg554 on
motiebrown
  • 215 Answers
I have a new cell - moz-screenshot.pngmoz-screenshot-2.png User Guide (pdf) - UntitledThe instructions you need start on page 15
Posted on Jan 29, 2011
What does it mean by available devices when you turn blue tooth on on your phone
you can sometimes set the other bluetooth devices to be discover able . If you don't the phone won't see the devices via bluetooth .
Sometimes when you put a device in pairing mode it is making its self discoverable other times you have to set it to be discoverable and then put it in pairing mode.
Bluetooth is a low power radio system that connects devices together.
Say you had taken a photo on your phone well with a computer paired to your phone via bluetooth you can share the file via blue tooth to the computer via the radio link blue tooth system.
If you had a bluetooth hands free system in your car you could pair it with you phone and use it with the phone .
Mar 07, 2018 | Cell Phones
How do I pair this bluetooth device to a phone
First step is to turn the blue tooth power to on in your phone menu,then you must put your blue tooth device into discovery mode,Now most blue tooth manufactures use the power button for thiws feature,when turning your device on keep holding the power button sown for 6 to 10 seconds a solid light usually stays on,this means you are in discovery mode,then you can add new or search for device from your phone menu,once it finds it it will ask for a pin pairing code.Most manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999. enter one of these codes starting with the first one ,when it recognizes the pin it will pair and you are ready to use your blue tooth device,glad to be of assistance
Feb 26, 2011 | Motorola Mobility Motopure H12 Bluetooth...
I am trying to pair the jwin JB-TH130 with a MyTouch 4G cell phone and the phone will not recognize the bluetooth device.
You have to put your blue tooth device to discovery mode usually you hold the power button down for 6 to 10 seconds when turning on you blue tooth device then you will have to make sure to turn your blue tooth power on in you menu then you can add or search device once they pair you will need a pairing pin code .Most blue tooth device manufacture use a factory pin pairing code they are as follows 0000,1234,9999,or 1111 i hope this helps
Feb 19, 2011 | Jwin JBTH130 Bluetooth Headset
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
How do I put the Blue Tooth device into pairing mode?
first switch on ur mobiles bluetooth connection......... then switch on ur moto H350..... then it automatically ask to pair with ur mobile jst accept it........ and then enter the pass code 0000.........kkkk... then it get paired... kk..........
Oct 26, 2008 | Motorola Mobility H350 Wireless Headset
Bluetooth
To all with problems with bluetooth pairing.when you push button to turn on bluetooth headset ,hold button until steady light stays lit,then put phone in pairing mode,when ask for passcode enter 0000,which is the standard code for pairing bluetooth.
Mar 27, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola Bluetooth® Headset H555
This will vary depending on the model of your phone. First off, you need to ensure that you are using a bluetooth enabled phone.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
Jan 14, 2008 | Motorola Mobility Bluetooth Hands Free...
Blue Tooth Pairing
I think that you are usiing an uncompatable headset or your doing it wrong.
How to pair your Bluetooth Head Set:
  1. Turn your Bluetooth on, on your phone.
  2. Turn your Head-set on.
  3. On your phone, in the bluetooth menu; go to "Look for Devices".
  4. Your phone should automatically detect the headset and allow you to connect.
Try http://carphonewarehouse.com to see if your bluetooth head set is compatable.
Jan 02, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Motorola Mobility Bluetooth Headset-Silver/Black Headset Logo
194 people viewed this question
Top Motorola Mobility Radio Communications Experts
Watching Him
Watching Him
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
