Question about Precor 933 Premium Series Treadmill
I have a precor 933i treadmill. After 4 yrs of use, I tried to view the lifetime odometer and hour meter. Both readings are malfunctioning providing lifetime odometer values that are one day 0km another day 10km, another day back to 0km. The interval odometer per run is working fine, just the lifetime odometer and hour meter is bad. Any ideas of what could be wrong?
Posted by shinsplin76 on
Stephen Miller
  • Precor Master
  • 1,645 Answers
1 Related Answer
Anonymous
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
Precor 933i where are fuses
Remove the the black and red wire from the Motor control board, get a drill battery and touch the wires to the positive and negative. If the belt moves, then I would say to replace the MCB.
Mar 01, 2015 | Precor 933 Premium Series Treadmill
Precor 9.23 Treadmill Inclines Randomly
most prob one of sensor / connection gone bad
Mar 30, 2014 | Precor 9.23 Treadmill
Precor L5 error
Precor Error LS, Speed Sensor Signal Missing Probable Cause 1. Intermittent or open connection of the speed sensor (reed switch) wiring.
2. Reed switch is defective or has intermittent connection.
3. Drive motor brushes are bad.
4. Lower PCA is bad.
Corrective Action
  1. Inspect the speed sensor (reed switch) wiring for damage or poor connection to the lower PCA. Replace damaged wiring or reset connection as necessary.
  2. Using an ohm meter, test the reed switch while rotating the drive pulley. The reed switch will close when the magnet passes in front of it.
  3. Inspect the drive motor brushes and replace if necessary.
  4. Test unit with a known good lower PCA. Replace lower PCA if necessary.
Precor Error Code LS
Dec 19, 2013 | Precor C954i Commercial Treadmill
My 933i is tripping my house circuit breaker at higher speeds. I think there is more resistance in the belt (It's never been serviced).
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt monthly. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine. -
Precor Repair Parts for 9 21s 9 21si Treadmills Consumer SPORTSMITH net
The following link will take you to our tech support page that contains some tips and videos on how to maintain your treadmill:
SPORTSMITH LLC
Sep 21, 2013 | Precor 933 Premium Series Treadmill
Precor usa treadmill c962i error 41
Precor Error 41, Lift has not Responded in Acceptable Time Probable Cause Error 41 was present in early software versions and is no longer being used.
Corrective Action If you encounter a unit that has software with an error 41, diagnose the same way you would if getting an error 40.
Precor Error 41
Precor Error 40, No Lift Motion Detected Probable Cause 1. Blown lift fuse in lower PCA.
2. Lift motor is physically jammed and not able to move.
3. Bad lower PCA.
4. Bad lift capacitor.
5. Bad lift motor winding.
6. Bad interconnect cable between upper and lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Check the lift fuse from the lower PCA. Using an ohmmeter, the fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the fuse is open, refer to steps 3 and 4 before continuing.
  2. Disconnect the lift motor from the ramp (elliptical) or lift platform (treadmill). If the lift nut or lift tube is jammed against the motor housing, turn the lift tube or lift nut away from the motor housing. If the lift was jammed, refer to step 3 before continuing. Calibrate the lift motor per the proper procedure for the unit being serviced and reattach the lift motor to the ramp (elliptical) or lift platform (treadmill). NOTICE: You must find and repair the cause for the jammed lift. Only re-calibrating the lift motor will not solve the problem.
  3. One of two modes can cause the lower PCA to fail. The lift switch could fail in an operated condition. If this happens the lift will move (either up or down) as soon as the unit powers up. The usual result is that the lift will be physically jammed as explained above, and probably also being cause for the lift fuse to blow. The lift switch could also fail in an open condition. If this happened, the lift would not operate in one direction. If either of these conditions occur the lower PCA needs replaced.
  4. Most units have the lift capacitor mounted inside the lift motor, and others use external lift capacitors. This information applies to units with the external lift capacitors. If the lift capacitor is shorted the lift fuse blows. Check the capacitor for a short using an ohm meter. Disconnect the capacitor from the lift motor and test. A good capacitor reads in the millions of ohms. Replace the capacitor if the reading is significantly low. Capacitor can also fail in the open condition which would result with the lift motor trying to run but not having normal power. Test the capacitor by measuring AC voltage across it. A good capacitor will read AC peak voltage while an open capacitor reads AC RMS voltage.
  5. When a lift motor winding is bad the lift will not operate in one or both directions depending upon the exact fault in the motor. Check the lift motor winding with an ohm meter. AC lift motors have a split winding (3 wires) and DC lift motors will have a single winding. Both windings must be checked on an AC lift motor. Normal winding readings could vary anywhere between 1 and 60 ohms, depending on the lift motor being tested. See the proper service manual for the motor being tested.
  6. Test unit with a known good interconnect cable. Replace the interconnect cable if necessary.
  7. Test unit with a known good upper PCA. Replace the lower PCA if necessary.
Precor Error Code 40
Jan 23, 2013 | Precor C962i Treadmill 220V
Precor 933i belt error
Please read my personal TIPS for treadmills and test it.
However LUBE inmediately the deck belt, this happen because the lack of maintenance by 5 hours aprox, So the system protect itself for electronic system and shut down.
2) LUBE the rollers bearing too.
3) Test the main motor bearint, measure the input voltage motor, if there are the motor is faulty. Repair. see my personal TIPS
God bless you
Nov 15, 2012 | Precor Exercise & Fitness
Precor treadmill error L5
Corrective Action
Feb 25, 2012 | Precor 935 Premium Series Treadmill
Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
Jan 10, 2012 | Precor 9.21 Treadmill
Unlock the code on Precor treadmill?
Dear Sir:
Please try with this Reset system for Code:
    • 1
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    • 2
Press the "ENTER" button three times to access the treadmill's error log.
    • 3
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    • 4
To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
    • 5
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
If you need further assistance, please reach me. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 23, 2011 | Exercise & Fitness
What's your problem?PRECOR EFX 546 ERROR CODE 43
Precor Error 43, Zero Switch not Found Probable Cause 1. Bad rotation sensor or missing magnet.
2. Lift position actuator does not physically operate the zero switch.
3. Bad lower PCA.
4. Bad zero switch.
Corrective Action
  1. Inspect for presence of magnet in the magnet holder. Replace magnet if missing. Check for output of the rotation sensor and follow signal all the way to the upper board. If the sensor has no output, replace. If the signal drops out at the cable, replace the cable.
  2. The lift platform mounting or the zero switch mounting plate could have physical problems that could cause the actuator knob to miss the zero switch as it moves past. Inspect and repair the lift platform mounting if necessary. Inspect and repair or replace the lift switch mounting plate if necessary.
  3. 5VDC is provided to the zero switch from the lower PCA. You should get 5VDC across the zero switch when it is activated. If the reading is considerably low, remove both wires from the zero switch and retest for voltage directly through the wires. If the reading is still considerably low, investigate the zero switch wiring. If the wiring is good and connected properly, replace the lower PCA.
  4. When a zero switch is bad or not actuated, the system will go through the entire search process and continue passed the home switch to find the lower limit switch. Move the lift to a position where the zero switch is not activated and remove power from the treadmill. Remove both wires from the zero switch and check the zero switch with an ohm meter. The zero switch should read near 0 ohms. While the ohm meter is still connected to the zero switch, activate the switch by hand and the reading should change to infinite (open). If either reading is considerably incorrect, replace the zero switch.
Precor Error Code 43
Oct 14, 2011 | Precor EFX 546i Elliptical Version 4
Precor 933 Premium Series Treadmill Logo
360 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
