Question about Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer
Where do I get an ink absorber box for my brother dcp-135c printer
Posted by brian_parkla on
Nikolay Boychev
  • 525 Answers
There is no reason to clean or replace. Just reset counter with this procedure.
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Feb 02, 2011
  • patel_bea Feb 02, 2011
    we were going to buy a new printer this weekend, thought this was worth a try, got nothing to lose. Didn't actually expect it to work!!!!!!! ; )) Brilliant, thank you.
My brother DCP-J140W printer ink box full .. please help how to fix it.
The Brother manual says that you are required to replace the ink absorber box at a Brother Service Center. This is not an item covered by warranty.
http://www.manualslib.com/manual/437931/Brother-Dcp-J140w.html?page=44
Sep 09, 2014 | Brother DCP-J140w Wireless Compact Inkjet...
DCP-135C after inserting new inks message reads "Maintenance and users guide chapter 46 cannot clean" Will not print.
Dec 01, 2010 | Brother Office Equipment & Supplies
How do I replace the ink absorber pad, where in the printer is it.
Hi There
To get at the ink pads all the printer goto be taken apart it a big job, you cant miss the ink pads when you open the printer apart it one big mess of ink there.
All the best Pineworks
May 02, 2010 | Brother DCP-135C Flatbed Digital MFC...
Clean unable 46
46 says the ink absorber box and flushing box are full, you need a shop to replace these and reset the counters. It's possible to just reset the error but you risk printer damage if they overflow.
Feb 01, 2010 | Brother DCP-135C Flatbed Digital MFC...
DCP-135C printing crooked
Hello! I need help!
My Brother printer - DCP-135C
I've changed all inks include the colours.
I able to print the Red, blue and yellow. But I can't print the Black.
I've tried pressed the cleaning option for many times.. Please advise some help.
Rgds, V
Jan 17, 2009 | Brother DCP 130C All-In-One InkJet Printer
DCP-135C
I have ink in my printer. But it doesn't print. always it displays the message INK NEAR EMPTY. how can i rectify that problem?
Jun 15, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer Logo
833 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
