SOURCE: Mitsubishi VS-5041 50 Inch Rear Prorjection TV No image but there is sound!
After 11 years???? OMG This set is a tired pup and should be put to reast. My experience with older sets and your complains are all capacitor problems and is only gonna get worse as the first time around repair will take several capacitors to repair. This set has no user serviceable parts inside so you should not attempt a repair suchj as this on your own.. This repair if you decide to go through the first time will be About 300 to 600 bucks the first time and cost will continue to raise till the sets put to sleep. Good luck
SOURCE: TV suddenly shuts off and lamp light comes on, but lamp is OK
did you reset the lamp timer? just a guess
SOURCE: Mitsubishi WD-52525 DLP HDTV screen went bad
I WORK AT A TV REPAIR SHOP AND WE WORK ON MITS. IT IS GOING TO BE 1 OF 3 THINGS. 1.CAPS 2. LIGHT ENGINE 3. FORMATTER BOARD HOPE THAT HELP (MAYBE LOOKING AT $750 TO $1250)
SOURCE: I have a Mitsubishi VS-50607 with a Code 24 Problem
its just a condenser(capacitor) ..so just try to locate it ..from the image board..cause Im sure that all this time the sound its still on ...just carefully measure 'em all and locate it ...after that just change it with another one or try to put something similar on the same size.. I can not tell you the exact one cause Im not familiar with the model ...but I do had this problem with the concentrated horizontal (middle screen ) line ...and always was about this ....
SOURCE: I have a Mitsubishi WD-52327.
Replace the Lamp P/N 915PO20010 if it has never been replaced.
Mats Electronics has them for $99.00 1-800-628-1118
