If your ITUNES for some reason not working, here is a tutorial how to completly clean 1. Download "WINDOWS INSTALLER UNINSTALLER CLEAN UP" and install from
your computer from Itunes, and fresh install it again.
Problems that this tutorial fix:
-iTunes has encountered a problem and needs to close
http://support.microsoft.com/kb/290301
2. Select and Remove Itunes, Apple software Update, Apple Mobile Device Support,
Bonjour.
3. Uninstall all that from Add/Remove programs in Control Panel.
4. Download "REGISTRY CRAWLER" from http://www.4dev.com/software/regc.exe
and install
5. Start Registry Crawler, and in Where to Search select all (keys, values, hkey_users, hkey_current_user, all......)
6. In Search For type "apple" and delete all entries, than type "itunes" and delete all entries
6a. If for some reason you cannot delete the selected entries you folow this procedure:
- Double click on selected entries in Registry Crawler (the regedit.exe will open point to the selected entry.
- On that entry right click, and select "Permissions" and than 'Full Control" - Alow...
7. You deleted all entries in registry for Apple and Itunes
8. Click Start, than Search..Select to search in drive where windows folder is.
9. Type "apple" and delete all files that have that name
10. Type "itunes" and delete all files that have that name
11. That's it...You seccessfully clean your computer from ITUNES.
12. Now install Itunes from www.itunes.com
Posted on Jan 29, 2011
Try doing a system restore on your computer to an earlier date when you knew iTunes was working fine. For additional information about System Restore, Navigate to http://support.microsoft.com/kb/306084
How to start the System Restore tool from a command prompt in Windows XP
Backup your itmes . Locate your iTunes folder: 1. By default, the iTunes folder is located in: 2. If the iTunes folder is not in the default location listed above then you can find where the iTunes folder is located by following these instructions: Drag the iTunes folder to another Folder ..somewhere save.. This can take a while if you have a lot of items.
Mac OS X: /Users/username/Music
Windows XP: \Documents and Settings\username\My Documents\My Music\
Windows Vista or Windows 7: \Users\username\My Music\
click here to download the windows installer uninstaller clean up .
To launch Windows Install Clean up.Go to start/all programs.
First of all backup your itunes library ...then uninstall the program. Locate your iTunes folder: 1. By default, the iTunes folder is located in: 2. If the iTunes folder is not in the default location listed above then you can find where the iTunes folder is located by following these instructions: Drag the iTunes folder to another Folder ..somewhere save.. This can take a while if you have a lot of items Thank you!
Follow this steps in order to backup itunes .
If you still need assistance, You can reply to this message at any time.
Thank You!
It is ok.
Download and install UPH Clean from microsoft ..click here.
Hi, I am Steve, lets get you some help
The Bonjour service is the Communications Handshaking system and it is use by a lot of other applications, itunes included.
There is a know issue between Advanced System Care, itunes and Bonjour causing the problem you have described. The solution is to remove itunes and advanced system care, reboot then re-install itunes followed by a new download of the latest advance system care and re-install that. do not use the advanced system care auto update.
An alternative is to disable sharing within itunes - it no longer uses the Bonjour service then - but no good if you want to share your itunes tracks.
Finally, there are issues with bonjour, itunes and some security products - the solution is dependant on the security software you are using so if neither of the above work for you please let me know your security software and I can give you the solution.
Posted on Jan 28, 2011
As you don't know what it is it is almost certain you don't have it installed. we need to look at the security software - what anti-virus product are you using?
ok, lets go for the simple solution
Hi, I think the reject is because I did not answer you inside 4 hours. I will pass this to my rep and they will sort out that side of things once we have your problem solved
start run services.msc (not service.msc, my typo sorry) in the services list stop Bonjour and disable the service. Then start itunes and let me know whether you get an error.
yes I got an answer - so we have disabled bonjour yet it is still generating an error. Hmmm.
Ok start run eventvwr.msc and in the application log find the error that comes up - either itunes or bonjour - copy the description and post that for me - I will take a look at it.
just got your e mail, I am out of the door now myself. I only get an e mail when you reply to me, not for a reply to someone else or a generic reply. I have just caught up with your other posts. Cannot see anything said to another expert.
I will go through everything I can see when I am at my desk later (in about 6 hours).
got your message. Seen a couple of error messages from the event log. It seems that the Bonjour service is starting. can I check, you have the service set to disabled?
Based on that error the next step is to update your version of dot net. What version of Windows are you using?
using Internet Explorer go to www.Windowsupdate.com and let it download all the fixes needed.
Sounds like your machine had a lot of downloads to add. The key one is the dot net download.
Jun 12, 2017 | Cell Phones
Jul 28, 2014 | Apple iTunes
Apr 21, 2012 | Apple iPod touch
Dec 09, 2010 | Computers & Internet
Sep 06, 2010 | Apple iTunes
Aug 04, 2010 | Apple iTunes
Dec 30, 2009 | Apple iTunes
Jun 15, 2009 | Apple iTunes
214 people viewed this question
Please be patient with me as I am not a guru; what is advanced system care, where do you find it and how do you uninstall it and where do you find the download to re install it. Thanks Darryl
Hi Steve, I will have to go now but will be back in about 10 hours. The Security software is CA ( Computer Assosiates)" Internet security suite plus". I did look in Add and Remove hardware but could not see Advanced System Care! Is it something that I should have and where do you find it, and what does it do for you? Look forward to your reply! I'll check in about 15 minutes to see if you require any further information. Thank you once again. Darryl
Hello again, I tried "service.msc" and it says windows cannot find anything. "start run eventvwr.msc" is a 512 kb file, bonjour reports all mentioned as type-information; category-none; event-100. I went control panel/admin. tools/services and it claims that bonjour is off but minutes ago when I started the computer and connected to the internet (mobile wireless broadband) bonjour said it had trouble as usual. Thanks Darryl
Hi, I am very new to FixYa, and I have been replying to your suggestions to keep you updated and I do thank you for your time. When I logged in this afternoon I received a message that I did not accept your solution and basically they say that I have rejected you but that is not the case, so I don't know how to undo whatever I have done to reject you. Sorry if I have caused any problems. Thanks Again, Darryl
Hi, Thanks for your suggestions! For an amatuer like me, what you have suggested could take some time but before I start I would like you to assure me that all the purchased items from itunes will not be lost. Thank you for your time. Darryl.
Hi, good to see you back! It doesn't worry me if it takes hours for someone to respond as I jump on the computer when I get a chance, type a question and come back later usually evening and morning. I am in Australia and if you are in the northern hemisphere such as USA then we are at opposite ends of the day. I just tried your suggestion and it was the same end result as going control panel/ admin. tools/ services. It claimed to be disabled from the last time but minutes ago when I started up the computer it said Bonjour has encountered a problem and needs to close. When you were rejected, another person came to help and they wanted me to download extra help to completely wipe itunes, from different directions. I replied that, I would like a guarantee that I would not loose all the purchased items from itunes. I have not yet checked for his reply. P.s. part of my problem is that itunes sometimes freezes and you have to go ctrl/alt/delete and choose to end non responding program.
I hope you just got my long message because when I clicked submit it didn't load as usual it just dissapeared! I could be at fault for your rejection as well because there are three ways I can reply 1. Add a comment for ..... 2. reply ( beside your advice) 3. (under Accept this solution ) Continue working with this Expert by posting more comments - Reply to ........ And I thought that all roads lead to Rome, don't they? Thanks Darryl.
Thanks for your reply, be patient with me as I only use the computer a bit in the morning and evening, so I don't mind your speed of reply. I Think I need to purchase an external hard drive and back up (should have done it a long time ago) itunes as it is 7.9 days 15.15Gb, we have quite a bit of music/audio books/childrens show/podcasts etc.
Event Type: Information
Event Source: Bonjour Service
Event Category: None
Event ID: 100
Date: 30/01/2011
Time: 8:16:47 AM
User: N/A
Computer: HOMEPC
Description:
Service started
Event ID: 100
Date: 30/01/2011
Time: 8:16:47 AM
User: N/A
Computer: HOMEPC
Description:
Service started
Sorry, Using ctrl/C that is all I seem to be able to copy!
This might be what you really expected:- Hanging application iTunes.exe, version 10.1.14, hang module hungapp, version 0.0.0.0, hang adress 0x00000000 and for Bonjour in the description it says "Service Started"
Hi again, I am curious to know if they will let you keep working with me or not! I am not in a hurry but I will wait for your reply before I move on the advice that I received from the other man. ( about deleting all things "itunes" and starting afresh) Many thanks for your time, Darryl.
Thanks, I will heading to bed shortly myself!
Hi, I have just replied to you thru a different avenue. I don't know if you are able to reply back to me more than once. So I have clicked on "Continue working with ......" , rather than replying to your individual messages. See what happens !?
Hi, I just went control panel/admin. tools/services , and tried once again to disable bonjour. Strangely enough, it wasn't disabled; so I tried again, this time, it took quite a while (2min.app.) and I got a message like never before, "Could not stop the Bonjour service on the Local computer. Error 1053: the service did not respond to the start or control request in a timely fashion." On previous attempts, I saw a small screen with one of those progressive green bars that fill up with the little green squares as things begin to happen. When I have clicked on the stop service option, this green bar would 1/2 fill up and dissapear; maybe because there was another window opened about the bonjour service that said it had encountered a problem and needs to close.( microsoft ), and I usually clicked, "don't send" and maybe that caused the other window to disappear. This time I clicked on nothing and just waited, the green progess bar 1/2 filled quickly and then very slowly from then on, to the above message that I quoted about Error 1053.
Hi, We have Windows XP Professional!
Hi, I went to windows update and downloaded priority/hardware/software optional downloads! That in itself was a challenge because at one stage the computer wouldn't respond for me, it froze! We usually don't get the user log on window, but now we get it all the time, even when the computer screen goes into sleep mode now, we have to log back in. That is no drama but between one of the downloads it went to sleep and it would not wake up, the user panel was faint and would not highlight for us. Even cntrl/alt/delete would not open so we could close down, so I chose to shut down, it said other people were logged on to the computer and their connection or whatever may be lost; but we are over that hurdle now. I'll see how we go. I purchased an external hard drive today, so I can back up iTunes purchases and try and totally remove and re install as you earlier suggested and also the other expert suggested, along with some download "help to remove" programs. Thanks again for your patience. Darryl
P.S. I just went back to the microsoft site and clicked on the review history of updates. And I counted about 12 that referred to Microsoft.Net Framework, Security and other things. Thanks again. Darryl
Hi, I have obviously taken too long and they have closed the case on me but that is ok, I can start again. I have copied the iTunes files to a hard drive, but I didn't realise that they are now missing from the iTunes program. When I get some more spare time, I will attempt to wipe the iTunes program completely and start again! See how I go. Thanks for your time and patience.
