Advanced Technology,The buletooth headphone ensure clear speech within 10 meters and high-fidelity stereo music .
Protect the earbuds when you during runing and workuots have sweat.Compatible with iPhone 6/6s,6 Plus/6s plus, 5 5c 5s 4s,iPad Air, Samsung Galaxy S6,S5,S4,S3 Note 4 3, HTC M9 M8 M7, LG Flex 2 G3 G2, and Other Bluetooth Android IOS Smart Cell phones/Devices
try updating your I-pod on the iTunes software on your computer if that doesn't work back up your I-pod on the iTunes and then reset your I-pod to factory settings. now if you backed your I-pod up properly then log back into your I-pod with your iTunes account and plug it into your computer, it should automatically restore all your apps and music ect. then you should be able to sync what ever u want again the problembeing is u probanlypicked up a virus or something on your I-pod
Hi, when a apple i pod freezes and refuse to function, it means that the i pod memory has stop working due to an application you installed in the i pod.
To rectify this problem, you will need to flash the i pod for the memory to start working properly.
Flashing an i pod helps you restore lost memory. After flashing the i pod, you can now start using it again as normal.
Check that pod has a punctured hole on BOTH ends.. If the bottom or to wear not punctured this will happen with most Keurigs.
Replace the pod holder if defective.
Tap foot to activate foot pod?
To pair Forerunner 305 with the Foot Pod:<code>Power on the device
Press mode to access Main Menu
Select Settings
Select General
Select Accessories
Select Foot Pod
Select Yes under Foot Pod
Select Restart Scan
Walk while device searches for the Foot Pod
Wait for the alert Foot Pod On or Foot pod detected. Use indoors?
If prompted for Use indoors?
If you want GPS off, Select Yes
If you want GPS on, Select No
https://www.reddit.com/r/running/comments/1ehr5d/cant_get_garmin_foot_pod_to_work_am_i_missing_how
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
