SOURCE: philips universal remote control cl034
hey i tried this and it worked. hold code search till the light stays lit(it may take a couple of secs ) then after its lit press tv and then keep pressing channel up or down till the channel on your tv changes when does press mute to save the code. also the power button will work to during code search , but i use channel because if you accidentally skip your code you can go back the other way. you might need to take out the batteries then re-insert to reset any previous codes. hope this works for you guys as well.
SOURCE: I need codes for a phillips tv and a phillips universal remote?
Hi michaeljlent,
There are a number of codes for your remote that correspond to Phillips TV models. They are:
002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
For your reference, here's a web address where all the codes for your remote are listed (along with programming instructions):
http://www.universal-remote.net/philipsmagnavox.html
I hope this helps - please let me know if I can be of any further assistance.
SOURCE: Phillips DFR 1500 No remote/Universal Remote
You can try to find the code for your remote on this website for Phillips Magnavox universal remotes. http://www.universal-remote.net/philipsmagnavox.html I hope this information helps you with your problem.
