Question about DeLonghi DCU60T Coffee Maker
Hi ,Does this coffee maker require filters? How many scoops of coffee for 60 cups?? DCU60T
Posted by leidigs on
D. Floyd Kolb
  • DeLonghi Master
  • 43,501 Answers
No filters needed... just dump the coffee on the top pan....
I like my coffee strong and use about 1 cup per 10 cups of water....you may want to adjust to your tastes...
We use one of those units at church... they are a great unit...there they use a bit less cause many don't like it quite that strong...like 3/4 cup per 10 cups....
heatman101
Posted on Jan 28, 2011
I have a coffee maker that makes 36 cups of coffee. How many cups of ground coffee should I use to brew 36 cups?
I would ordinarily use half the amount of scoops of coffee as the amount of cups the coffee maker makes. A scoop being a Tablespoon of ground coffee. Less if you want it weak and one or two more if you want it very strong.
Apr 09, 2011 • Vacuums
How many scoops do I use in a Farberware 30 cup coffee maker for 30 cups?
About 3/4 cup of coffee will make 10 cups of strong coffee...
adjust to taste...
heatman101
How do i make coffee in a 60 cup urn...i have no instruction manual
Hi, 2 scoops of coffee for every 3 cups. Then make adjustments to taste.Ron
How many scoops per cup?
Hi. normal is 2 scoops of coffee for 3 cups of coffee, then adjust from there for your taste. Good luck.
For 55 cups do I use a one pound can of coffee? And what about 36 and 42 cups...how much coffee do I use? [email protected]
Hi, use 2 scoops of coffee for every 4 cups ( not mugs) of coffee, on all the urns.Good luck. ron
2answers
How many scoops of coffee for 36 cups?
the traditional wisdom is one scoop per cup and one for the pot
2helpful
Looking for glass tube for delonghi 60 cup coffee urn and glass button top, i believe the model is dcu60t
Here is a number you can try, to obtain a replacement part:
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
Hope this helps... Good luck!
How to make coffee with the toastess coffee maker
If the scoop is 1 tablespoon, use two scoops of ground coffee for every six ounces of water you are brewing.
If the scoop is 2 tablespoons, use one scoop per six ounces.
Also be sure your grind is proper for the type of filter you are using.
DeLonghi DCU60T Coffee Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Pierre Laplante
Michael Thomas
Michael Thomas
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
