Pearl C70w Double Braced Cymbal Stand - New In Box Logo
Anonymous Posted on Jan 28, 2011
The clamp on the top of the stand that holds the cymbal down is stuck and cannot be screwed off. My cymbal is stuck on the stand, and its extremely difficult to transport now.
Fred Yearian
Level 3:
  • Pearl Master 5,603 Answers
  • Posted on Jan 28, 2011
Fred Yearian
Pearl Master
Level 3:
Answers
5603
Questions
Helped
2248615
Points
16162
Try lubricating it with a penetrating oil such as "Blaster: or other brand available in automobile parts stores. Let the oil penetrate a bit before trying to unscrew it...
Also you can try heating it with a hair dryer to help break it loose.
When finally free, spray some CRC226 periodically on it to keep it free... You can get that at Home Depot in the electrical dept.
  • 1 more comment
  • Anonymous Jan 28, 2011
    the problem is, im not trying to damage the cymbal thats on it, so it'll be hard to manage with any of those things
  • Fred Yearian Jan 29, 2011
    The blaster penetrating oil will NOT damage the cymbal and even a bit of heat from a hair dryer won't... the felts might have to be replaced. The CRC 226 is completly safe and is safe on plastics even. You probably want to have two people to manage holding while working on it to avoid damage... they are awkward for sure... You can clean any residue of the blaster oil off with Isoprophyl alcohol when you get it loose. If the threads are gauled, find a tap and die and clean the threads out before assembling again. CAUTION: The threads MAY be metric so make sure to have the right tools. Also if it is a double thread where they have two threads running at once, those you have to live with as tools aren't available... in that case use a wire brush to clean out the threads. The 226 applied once a month or so will prevent further rusting.
  • Anonymous Jan 29, 2011
    k thanks
Tuning
I'm sure its tuned like a drum, use the lugs. As for the stand, a standard cymbal stand should work.
tip
Studio Recording at Home; Part Deux
This tip, continuing the series of Home Studio Recording, focuses on the hardest part of accomplishing this feat: Drums.
A big sound killer on 'budget' recordings is poorly recorded drums. There is a remedy, though. If you have one set of drum mics, buy another (or borrow. This will come into play later, though).
If you have clips that hold them on the drums, great. With the two sets, you'll only use half of the clips. For the rest of the mics, you'll want stands. You'll need one stand for each drum, plus six.
The dual mics serve this purpose: To capture the sound of the whole drum. One mic for the batter head (the side you hit), and one for the resonator (the side you don't).
For the batter head, you'll use the mic clips, and attach the mics as you normally would during playing. For the resonator head, use the stands to position the mic directly across the drum, making a straight line from the top of the drum to the bottom. This will help eliminate any voicing differences, which can be a real headache.
For the bass drum, you'll need 2 stands. Position the batter head mic close to the edge of the head on whatever side is easiest to access, but is also comfortable for your playing style.
Aim the mic so that it is pointed at a midway point between the center of the head and the edge. You can experiment with different spots, but be sure to NEVER let the mic be directly in front of the head.
For the bass resonator head (the front one that everybody sees), position the mic so that it is a mirror image of the batter mic. Once again, this gets rid of voicing problems.
You have just miked your drum kit, but what about cymbals? That's where the other 4 mics and stands come into play. Those 4 will take care of:
Hi-hats
Ride
Overheads
For the hi-hats, you'll want to position the mic about 3-5 inches from the top, and 2-4 inches from the side. It's best to come in from the outside of the kit, so that you'll pick up a bit of ambiance (the rest of the kit, as well as some natural reverb). Point the mic at a point close to midway between the bell and edge of the hats. Too close to the edge, and you'll get a sound similar to banging trash can lids together. Too close to the bell, and there's too much high-mid noise that CANNOT be reduced with an EQ.
For the ride, follow the same instructions for the hi-hats, but add about 2 inches to the distances. Aim the mic a little closer to the center as well, so that the mic will pick up any bell hits. A good spot is 1/4 the distance between the bell and edge.
Now for overheads. These are the mics that not only record the cymbals, but pick up the most ambiance.
NOTICE: I haven't already mentioned it, but you do NOT want to record with the drum kit up against a wall, nor do you want it in the center of the room. For best results, use the midway rule (as with placing mics on drums and cymbals, place the kit midway between the center of the room and the edge, preferably headed towards a corner). This will reduce unwanted echoes in the room due to sound reflection.
You will want to place the overheads about 1.5 feet above the highest cymbal. Space them out so that the entire kit is between them, but be sure to keep them evenly spaced. You'll want to use the snare as a midway marker for the placement of overhead mics, since it is your loudest drum, and more likely to be picked up in the overheads than any other drum. This will also keep the snare panned center (you'll be panning the drums out to the left and right later on the mixer, but the snare and bass stay center).
These are some guidelines for setting up mics for recording drums at home. I hope that helps, and stay tuned for Part Trés of Home Studio Recording.
on Mar 13, 2011 • Music
1helpful
WHEN I STRIKE THE BASS DRUM, THE CRASH CYMBAL SOUNDS AT THE SAME TIME....EVEN WHEN NO CYMBAL IS CONNECTED TO THE INPUT JACK.
If you leave an input open they MAY cross couple... try plugging a set of headphones into the cymbal input jack... this will ground the cymbal input... then see if you still get the cymbal sound... IF you STILL get the sound, then the multiplexor that scans the input has a problem and you need to take it for repair. Repair on the surface mount boards is not a DIY without proper tools and skills. If the grounding stops the cross coupling, then you MAY have a problem with the cymbal or its cable.
How do you make it lower, its too high for the drums
These usually can't be shortened more than their lowest setting. Some cymbals you can get a bracket for, but the hi hat that is driven by a pedal that option is not available.
CROSSTALK
turn down the sensitivity of the cymbal piezo and that should fix it.
My High Hat is stuck in the closed position. I need help on fixing it. Please help, my band auditons are tomorrow!
Loosen off the screw that holds your top cymbal in place. See if that helps. If it doesn't, remove the top cymbal and unscrew the rod it sits on. See if that freed up the pedal. If not have a look at where the pedal attaches to the bottom of the rod. There may be a broken split pin there. If there is you will have to have it repaired. Hope this helps and sorry if you can't get it working for your audition. Maybe you can borrow one?
One of my cymbals just stop working, i've unplugged it from the cymbal, turned the amp off and on, restarted the system and nothing seems to be working. I did unplug it from the "brain" i believe, (i just...
Try these:
- change the interconnection cable between the cymbal and the "brain" unit, if the problem goes away, you have a bad cable.
- if the problem persists, see if that particular cymbal works well on another input of the "brain" unit, if it does, you have a problem with the input on the "brain unit", this will require servicing if the unit still has a warranty, otherwise you should first check the solder contacts on the input that doesn't work (also check for dirt /oxydation on the plug contacts and clean if necessary).
- If that particular cymbal won't work when you plug it into any "brain" cymbal inputs (it's basically a piezo trigger so it should work on other inputs), then you have either a broken wire on the piezo trigger or on the cable connector in that cymbal (it should be possible to resolder), or the piezo trigger itself is faulty and needs to be replaced.
I hope you can find out what troubles your drum kit.
regards
3rq8 (triarcuate)
1helpful
Assembling Odyssey Lstand
lol....after reading your problem and then posting mine I had an idea. I went to youtube.com and found out that in order to hook up the U CLAMPS...you have to disconnect the table top attachment and connect the U Clamps to the short bases. You then dont need longer screws you use the little black screws that came with the stand. I went to Guitar Center after I did mine and confirmed that theirs was set up the same way....lol...LETS PARTY NOW !! This calls for a celebration party...lol GOOD LUCK AND TEAR THOSE PARTIES UP
Top Pearl Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Pearl Music Expert? Answer questions, earn points and help others
