Your harddrive is bad, the motor bearing that spins your cylinder heads is damaged, even though the harddrive hasn't been dropped, or removed, this is a result of faulty and cheap product. Theres nothing you can do to replace the motor bearing, you will need to just get a new harddrive and install into the external hd enclosure or get a new external drive. If you decide you want to recover your files, you will need to take this harddrive out and maybe take it to bestbuy/ office depot where they will have to send your harddrive out to a data recovery center. They might be able to recover some data, or all, or none. It is a pricey move to take this step.
Testimonial: "Thanks for the prompt reply. Much appreciated. I will send the drive out to see if data can be recovered."
I also had the same problem with my externa Lacie drive. However my first reaction was to remove the drive from the housing and place it internally into my computer. The drive is an IDE Seagate. The HD checked out ok in my computer. I can buy the kit to make it external again but I have others. Give this a try before you trash it.
Thank you! I will give this a try first before I send my drive out to see if the data can be recovered.
Happy hard drive failure mode. Mr. Chang is correct on the analysis. The heat and constant rotation inside the HD makes the bearing fail. One option is to cool the HD in the fridge or freezer before turning it on. This may allow the bearing to "heal" itself long enough to get the data off and onto another drive. Another option is to remove the HD from the case and take it apart to replace the bearing. I have not been successful but it is worth a try if the HD is really dead. Reminder: Always good to back up the backup data. you never know when the HD will fail. www.teamgoldman.info
