Question about HP PhotoSmart 130 InkJet Printer
Put new roll in printer and paper feeds through then goes back out again
Posted by trendadm on
Anonymous
    Master:
  • 458 Answers
The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
Posted on Jan 28, 2011
1 Related Answer
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: Paper will not feed into printer. Goes in about 1
Check any tracks, wheels, and gears to see if there are any paper jams at all. Even the slightest little chunk can jam up the printer.
Posted on Aug 14, 2009
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    How to fix a paper feed error
    To fix your paper feeder follow the mention tecnique:
    1. open your printer paper feeder
    2.put off spring
    3. Then find out a white roll gide and open it.
    4. Open roll gide from the printer. Then open black roll from white case. In the hole a spring apear . put off the spring from there.
    5.Finaly assembel all the parts again without the spring.
    I think your printer may work again. Thank you.
    Aug 24, 2010 | Epson Stylus CX4800 All-In-One InkJet...
    Change paper
    Paper roll installation is deceptively simple.  No need to feed paper through any slots inside the machine as you might expect.  Just put shiny side of paper down, feed edge of roll out of machine and under the roller that is attached to lid, and that is all there is to it!
    Oct 28, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
    Putting new paper roll in
    It's difficult to see, but the feeder for the paper is on the back of the machine, just below where the roll of paper goes. You'll see a little slot above the opening for the batteries. Feed the paper in here and push the arrow up button above the ON/C button to get the paper feeding through the mechanism. It should pop out at the top!
    Jul 29, 2008 | Canon P200-DHIII Calculator
    Ribbon installation
    I searched this online, and have found the following instructions:
    1) Set the power switch to OFF
    2) Remove the printer cover
    3) Remove the ink roller by turning it counterclockwise and pulling it upward.
    4) Install the correct color new ink roller and press it in the correct position. Make sure that the ink roller is securely in place.
    5) Put back the printer cover.
    May 30, 2008 | Sharp EL-1801P Calculator
    How to get my Dell Photo 924 to feed paper for printing?
    if you are having issue with the paper feed ,moz-screenshot.jpg try these steps
    1. Unplug the power adapter
    2.open the printer cover , look for any obstructions inside , lift the printer and shake it firmly
    3.turn the printer upside down and gently tab on the base,.
    4. Put your Hand inside the Input paper tray and manually roll the two rollers
    5. Put back the power adapter , turn on the Printer and try to copy a document from the printer.
    Try all these steps and if you still have the paper feed issue then purchase the new printer
    Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
    Adding adding machine paper to the Ibico 1202
    Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
    First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
    Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
    Then, place the paper into the slot where the paper feeds in..Look in the back of the printer for a thin slot. (Usually goes under the printer1.gif assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
    Hope this helps.
    Have a good day.
    M =)
    Please remember to leave a rating or feedback if I have helped you with your question.
    Mar 21, 2008 | Ibico 1202 Calculator
    Load new reel of paper
    Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
    Hope this helps.
    Have a good day.
    M =)
    Feb 10, 2008 | Victor 1230-2 Calculator
    PAPER FEED
    Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
    Hope this helps.
    Have a good day.
    M =)
    Jan 16, 2008 | Canon P1-DHV Calculator
    HP PhotoSmart 130 InkJet Printer Logo
    137 people viewed this question
    efs_perpends
    efs_perpends
    Muntejaya Ginting
    Muntejaya Ginting
