HP OfficeJet K80 All-In-One InkJet Printer Logo
Posted on Jan 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It keeps telling me to install my color cartridge. And it is already installed. I've tried several different times. Will not copy either. [email protected]
  • 1 more comment
  • jkbroyles Jan 28, 2011
    This has been tried severla times and it still does not print any way. It is an HP officeJet K80
    My HP printer will not copy or print. It keeps telling me to insert the color cartridge. I have a dozen time or more.OfficeJet K80
  • jkbroyles Jan 31, 2011
    I had alreay tried this problem. I took out the old cartridge and inserted a new one. And it did not work. I cleaned it as it told me. I only use HP cartridges.It still tells me to insert the color cartridge. The print is several years old. But it has been a good.
Jose Cada
Level 3:
  • HP Master 3,530 Answers
  • Posted on Jan 31, 2011
Jose Cada
HP Master
Level 3:
Answers
3530
Questions
Helped
964774
Points
9839
Welcome to Fixya
Try to reseat all the cartridges and clean the metal contacts. Try to reset that printer. Unplug the power cord and Press and hold # and 3 while plugging in the power cord back.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Muzahura Frank
Level 3:
  • Master 2,071 Answers
  • Posted on Jan 28, 2011
Muzahura Frank
Master
Level 3:
Answers
2071
Questions
Helped
445468
Points
5838
Well assuming that you are using genuine HP ink carts and protective tape removed, it sounds like the ink carts are not seating well or the connections are dirty. This would cause the printer to not recognize the cart or think that it was reinstalled but not aligned. The age of the printer also makes sense.
otherwise,
Press and hold the Enter button, and then press Menu .
if still no luck, take out the cartridge and vacuum it.
Anonymous
Level 3:
Genius:
  • Master 1,637 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1637
Questions
Helped
289951
Points
4933
As soon as you installed it, you prompted a change in the ink levels which will AUTOMATICALLY pop up on your screen when you are properly connected and attempt to print something. That is when you tell the system that it is a new cartridge. OR YOUR PRINT HEAD IS CLOGGED Brother printheads are very easily clogged with air bubbles so there is very high risk that refilling ink will damage your printhead. It is not worth it to save money on ink and wind up with danmaged or totaly nonfunctional printheads.
  • Anonymous Jan 28, 2011
    It sounds like the cartridge sensor is blocked. Remove the cartridge, clean the sensor, replace the cartridge and when the system prompts you, ensure to tell it that you have installed a new cartridge. When your print head is clogged from using REFILLED CARTRIDGES, you will get the same errors.
  • Anonymous Jan 31, 2011
    Peek inside where that ink goes, if the spring on the right is dangling, or has poked a hole in the ribbon cable at the rear, you will need to replace the carriage assembly. Complete replacement is far more affordable
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
Re: The printer will not recognize the installing of a new color cartridge.
after installing a new cartridge you need to open the program for your printer tray and reset your cartridges so that the printer and pc reconize the cartridge is full
The magenta isn't printing correctly, and the printer keeps telling me to remove tape from the magenta cartridge. There isn't any tape on it. I've tried resetting it several times.
Its sounds as though the printer isnt picking up the cartridges properly, try removing it and cleaning the contacts on both the cartridge and the printer
Just replaced both ink cartridges on Kodak ESP 3. Will not recognize color cartridge. Both are genuine Kodak cartridges. Red light for color cartridge just keeps blinking. Have tried unplugging....
silly question, you remembered to remove the plastic film off the connectors right? i realize you did 2 different cartridges but hey sometimes thing get messed up lol. it may be a faulty cartridge, you should be able to return it if that's the case. the only way to know for sure is to take it back and get a different one. if that's the case problem solved, you could always power down the printer completely after installing the cartridges and rebooting it
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Error messages but I can't find the errors
ona brand new machine you get a starter cartridge, you will need to put in a new cartridge
1helpful
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Left Cartridge error on Lexmark X125
If you still have the old color cartridge, I would put it back in to see if the message goes away. It is likely that it is your new cartridge or something wrong with the housing that the cartridge is seated into. If you don't have the old cartridge, another new cartridge installed would determine if it is the cartridge or something to do with the housing. If after putting a different cartridge in the printer, you get the same message, then it is the housing.
Printing alignment problem
First thing to try is to remove the power brick (not just the cord the whole brick) from printer for a minute then re insert and try it again. If this doesn't help try uninstalling it then re installing the printer
Printer won't process new catridges. These cartridges have been refilled.
Did you install the original cartridge? if you have the old empty cartridge, try to install it and check the error is empty cartridge..if so the problem is the newly installed cartridge. try to buy the new original one.
k24674
Grand Canyon Tech
Grand Canyon Tech
