Question about Olympus Cameras
Olympus E-300 Evolt when you press the shutter button to take a picture, the shutter rapidly repets for about 9 times
Posted by rlichty32 on
Anonymous
    Genius:
  • 1,637 Answers
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
Posted on Jan 27, 2011
When take picture a flashing green light appears on display
Check that batteries are fresh. Check that camera hasn't been set for no-flash mode.
Give the flash time to charge before pressing shutter.
I purchased this camera months ago and hate it. I guess I dont know how to use it correctly. Any time I try and take pictures it seems like it take forever for the pic to take. By the time it clicks the...
You need to learn the "half-press". You press the shutter button half-way and allow the camera to lock in the focus (it will beep). Then, when the moment is right, you finish pressing the rest of the way for an instant picture.
Each time I press the shutter button to take a picture the flash keeps flashing fast on and off 3 bursts of about 10 flashed then it takes a pic ??? help
The built-in flash can function as an autofocus illuminator. This helps with focusing in low-light conditions in the AF mode.
To disable this function, press the menu button, then select service1 menuitem, then AF illuminat., and finally, select OFF.
My Evolt E-300 won't take a picture. Seems find until you go to take the pic and then the shutter opens and closes multiple times without any picture.
Try to set all menu items to default as much as you can. Some cameras have a reset to default setting or a button to reset to default.
After setting to default, try the camera again.
If all fails, this camera will need repairs.
If it is too old, and not worth it, it may be the best to sell for parts on a site such as Ebay.
1helpful
2answers
Olympus E-300 Digital SLR storing black images.
Most likely the shutter "curtain" (a few pieces looking like sheet metal just behind the mirror, designed to protect the camera CCD from dust and damage due to too much light) is not opening. This will require servicing by Olympus, since you will have to take the camera apart to be able to reach this camera part. Unfortunately, this may be a pretty expensive repair.
1helpful
Wet olympus E-500
PLease take the camera to a service station before the whole things shutsdown due to liquid damage .... normally it does not show immediately but in the long run it will give probs...
E-500 lock-up
Shutter speed too low and aperture probably set at wide open [3].
You will find that after two minutes the shutter will respond but you will get a blurry picture.
This setting is rarely used but you only learn from playing with different settings.
Olympus instruction manual needs to be in a better language for the beginner to learn.
Digital camera quite working
Check out the pins in the base of the card chamber- are any missing or bent? Next check out Mirror action- is it working? Try to get onto the Olympus Tech Support team. If it is broken I think a repair will not be an option- the cost if possible will be well on the way to the next camera This is my camera too - lovely under rated beasts
Can I take pictures while viewing subjects through the monitor of the camera?
No, you cannot because the Electronic Controlled Focal Plane Shutter and Mirror is in front of the CCD.
1helpful
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Cameras Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jax Planet
Jax Planet
Are you an Olympus Camera Expert? Answer questions, earn points and help others
