Question about RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA CUTTER 1-5130- 1
! light on error 80 ,replaced parts still no go .if i touch the tip to ground it clears it and air comes out but when you try to cutt the air stops and no arc ??
Posted by sid762 on
Crossfire vr2000d wont stop cutting out
Bad ground, possibility of some wires touching
Oct 25, 2017 | Crossfire VR2000D Car Audio Amplifier
I have water that is standing in the drain tube coming up from the ground.. now there is water dripping in the houseing unit in the house
The drain line is stopped up somewhere. If it runs into the ground then it's stopped up there. Dig it up or remove the line in the ground and clear it out. You can use compressed air or just blow on it to try to clear it. Add bleach to kill any mold and mildew that might stop it up.
Sep 09, 2010 | Heating & Cooling
Only cuts for 3 seconds, device still on
Possibly an internal short in the torch tip... the expendable components failing in the tip will cause the sensors in the machine to register a "no cut" or "free air arc" state and kill the power to the tip to prevent damage to the unit. Replace the tip components and double check the grounds connections.
Apr 03, 2010 | Hobart Airforce 250ci Light Weight Plasma...
My earphones suddenly stopped working all of a sudden. The sound in the left ear cut out and when I jiggled the wire and the connection a bit, the sound cut out completely. Now when I jiggle the...
Cutt the 3.5mm ********. You will need to cutt the cable about 10cm from the plug end to make certain you clear the damaged area. Buy a new Jack. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
Mar 20, 2010 | Skull Candy Lowrider Headphones
Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
Mar 14, 2010 | Heating & Cooling
96 suburban brake ligh don't work
you may have to change the brake light switch at the top of the brake pedal stop by your local GM dealership in the parts department and they be able to print you off pictures and diagrams but check on the part at your local part store because it maybe cheaper wish you the best of luck Michigan Man.
Dec 27, 2009 | 1996 Chevrolet Suburban
American Standard Freedom 80 - 9 blinks - Ignition issue
I will try to help. Your furnace has to have a good ground before the igniter will work. The draft fan starts purges for a few seconds and the ignitor is supposed to come on. If not check to see if the contacts on the air switch on draft motor are closing. If you ahve changed the ignitor that is not your problem. Another possible problem is the baord that feeds the ignitor. But check the air switch first Rus. Keep in touch.
Nov 19, 2009 | Heating & Cooling
Discs will not play
Could be a number of things:
1. The disc is dirty. Remove and clean with soft cloth. Remove fingerprints and smudges.
2. The disc is scratched. Remove disc, clean and try to repair with a CD scratch removal kit.
3. The disc is flawed. Remove, throw away and replace disc.
4. The camera laser is dirty. Clear debris from laser with canned air. Do not touch laser.
5. The laser is out of alignment. Professionally repair or replace camera.
May 01, 2009 | Disney 13" TV
1986 Chevy Caprice Classic Horn not working
Diagram should be on the inside of the fuse box or relay cluster lid/cover. If Test light has 1 wire and a sharp tip? Yes, but only if you push the horn button too ;-)
My guess is that the horn lost its ground, but you can check this with the light. The horn only beeps when both GROUND and Pos 12v are present. The horn button gives the relay 12v to close, and the relay gives the horn 12v to operate. The ground is always connected.
Connect tester clipwire to 12v source (battery, headlight (has to be on) and touch its tip to metal of car. Does it light? Good. the tester is working and the 12v is a good source.
Touch one of the 2 horn connection or wires (poke it thru the plastic - why tip is sharp). Does it light? Touch the other, does it?
If both light, (1 will be brighter) we can assume the horn coil is good and it is getting a good ground and I was wrong (it happens... but not often). The side that is BRIGHTER is the ground wire side.
Now have someone mash the horn button. Do you hear a tiny click? That is the horn relay. If not, look for the horn relay fuse and replace it. If you DID hear the click, the relay coil is good and is trying to switch 12v to drive the horn.
Now is time to locate and replace the horn fuse or the relay may have bad contacts. Look at the other relay part numbers in the cluster and see if there is a match for the horn one. Swap it out and try the horn.
Hope this all helps. To 'test' the horn, touch the dim side again anf listen for a scratching sound. That is the 12v going thru the tiny bulb in the tester (a resistance) and trying to drive the horn.
Good Luck!
Mar 27, 2009 | 1986 Chevrolet Caprice
Welder not welding
The contact tip is the main source of power, if the tip is bigger than the wire then you will not get a proper conection, the earth clamp is a essential part of the system make sure you have a good earth and all the conections are tight
Jan 14, 2009 | Clarke Power Products Clarke 130EN Mig 110...
RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA CUTTER 1-5130- 1 Logo
60 people viewed this question
Top RTO Welding Tools Experts
Bill Boyd
ray gallant
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
