Computers & Internet Logo
Posted on Jan 27, 2011
Dell inspiron wont boot windows..I have ran a pre boot system assessment build 4118... I am getting the error code 0142. msg error code 2000- 0142 please help
  • Anonymous Mar 16, 2014
    It keeps running a Memory Test Activity over and over.
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Jan 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
5337
Points
42
That error is normally a bad hard drive. Replacement is fairly easy and not to expensive, but you will have to reinstall a Operating System to the new drive.
Testimonial: "quick and answered my question thanks."
4helpful
3answers
Error code 0142 message error code 2000-0142
My computer did boot up to the desktop, but was completely unresponsive from there when trying to open anything. I ran a system diagnostics and got this error with the status byte of 70. I rebooted into Safe Mode and was then able to open files. I backed up my stuff to a flash drive and then ran Error-Checking in the HD Properties which runs the CHKDSK function the next time the computer is rebooted. That found 2 bad file clusters and repaired them. One was a file called Windows.edb, which does the hard drive search indexing for Windows and was most likely my problem with the lockups. The other was a Napinsp.dll file. After these were fixed and the computer was rebooted, everything worked normally.
This HD is only 9 months old, but if this happens again, I'll replace it again.
2answers
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
My laptop is inable to get past the microsoft loading page. I ran the test and got the error code: 0142. Msg error 2000-0142. Meaning there is a problem with the hard drive. I took out the hard drive and...
2000-0142 is an UNREPAIRABLE hard drive failure.
IF you can boot to windows, do so and copy any important data to a CD, DVD or external drive before it completely fails (If system will not boot in normal mode, try safe mode (F8 at boot)
If you cannot boot to windows, then you may be able to get a replacement HDD, install windows and drivers on it, then using a USB HDD adapter, see if you can find your data on the old drive.
Regardless, the only way to fix the computer is to replace the drive, there is no tool that will REPAIR a 200-0142 error on a hard drive, only replacement.
I did a diagnostic test on a dell inspiron 1525 and everything passed except the hard drive with error code 0142, what does this mean and can it be fixed, thanks.
Based on
Dell Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers - KB Article - 30042,
it is a Hard Drive failure, and you need to replace the Hard Drive.
I suggest to try reinstall windows first before you replace the Hard Drive.
Hope it helps you.
I did a diagnostic check and every thing past except hard drive, error code 0142, what does this mean and how do i fix. thanks
Based on
Hope it helps you.
Comoputer: DELl precision T5500 Workstation Problem: cannot start normally Error CODE 0142 Msg: Error Code 2000-0142 Msg: Hard Drive 0-Self-test unsuccessful Status: 72
sounds like a bad hard drive. Press f12 during the dell logo on startup and choose "diagnostics" from the boot menu, see if more failures relating to the hard drive are returned.
6helpful
How to fix a error code 0142 msg 2ooo-o142 msg unit:prive self test failed.stuaus for a dell labtop
Ok well I have a Dell Inspion 1525 and I have been having problems with it the last little while so I ran a diagnoses tests and I got this:
Error: 0142
Msg: Error code 2000-0142
Msg. Hard drive 1- self test unsuccessful status: 79
Just wondering what exactly it is, and how to fix the problem?
Or if I have to reformat my whole computer
  • 1 year ago
1helpful
3answers
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
