Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Invalid dim message? Trying to plot a histogram. All plots except Plot 1 are turned off. Cannot seem to figure out what is wrong.
Posted by laurenk2009 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Sep 19, 2014
5 Related Answers
Anonymous
SOURCE: I am trying to do a box plot with a TI-84 Plus
Hey. I had the exact same problem as you and all I could do was reset the settings to the default settings on the calculator. All you have to do is turn the calculator on, his 2nd (it should say mem right above it). Then click reset then RAM.
Posted on Sep 30, 2010
k24674
  • 8091 Answers
SOURCE: whenever i try the graph
You have to turn all statistical plots OFF before you draw function graphs. Press [2nd][Y=] to open the statistical plot configuration screen. Press [4:PlotsOFF] and then [ENTER]. When calculator answers DONE you are ready to draw function plots.
Posted on Sep 10, 2010
  • 102366 Answers
SOURCE: when i click graph it
Posted on Sep 06, 2010
Anonymous
SOURCE: invalid dim
turn off the stat plot by pressing 2nd button and then the STAT PLOT button.
Posted on Mar 18, 2009
Anonymous
  • 32 Answers
SOURCE: my TI-83 doesn't plot
The problem seems to be that the list is archived. To fix this go to memory menu (2nd and mem) then find L1 or whatever list you want and hit enter next to it. This will get rid of the big asterick and then you can graph it or you should be able to.
Posted on Dec 04, 2008
What to do when error;invalid DIM shows up on the screen?
INVALID DIM error message may occur
if you are trying to graph a function that does
not involve the stat plot features. The error can
be corrected by turning off the stat plots. To
turn the stat plots off, press 2nd (stat plot) ,and
• You specified a list dimension as something
other than an integer between 1 and 999.
• You specified a matrix dimension as something
other than an integer between 1 and 99.
• You attempted to invert a matrix that is not
square.
Sep 13, 2014 | Texas Instruments TI-84 Plus Calculator
Invalid dim
I assume you're seeing YList instead of Freq on that line. In that case go up and re-select the histogram or one of the box plot types.
May 05, 2012 | Texas Instruments TI-84 Plus Calculator
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
Error message invalid dimensions
y , and then select 4:PlotsOff.
Jan 19, 2012 | Texas Instruments TI-84 Plus Silver...
Invalid dim?
The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat
plots. To turn the stat plots off, press {2nd}[stat plot], and then select 4:Plots Off.
Jan 23, 2011 | Texas Instruments TI-83 Plus Calculator
What does "invalid dim" mean?
plots. To turn the stat plots off, press {2nd}[stat plot], and then select 4:PlotsOff.
Jan 19, 2011 | Texas Instruments TI-84 Plus Silver...
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
If this doesn't do it, could you post the exact function you're trying to graph?
Nov 16, 2010 | Texas Instruments TI-83 Plus Calculator
When I graph, it shows "ERR: INVALID DIM 1:QUIT"
Oct 28, 2010 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
789 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
